Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears
Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears Empty Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears
Post  bluef100fe June 9th 2011, 10:22 am
I'm trying to thin out the shelfs in the shop. Some parts are barely used and some are used but not hurt. All prices are plus the ride.
Pair of Comp engineering Rear shocks # C2705 19.5 extended and 12.35 collapsed length, adjustable 70/30, 60/40, 50/50. Stud mount top and eyelet bottom. Have 4 passes on them in my truck and 60 street miles. $50
https://i.servimg.com/u/f27/14/37/50/57/for_sa10.jpg
Pair of Rancho Rear Shocks # RS99115 20.625 extended and 13.25 collapsed length, these are the adjustable dial type shocks. They have less than 3000 miles on them and half a dozen trips to the track. $110
Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears For_sa21
Ultimate Converter Concepts 9.5 inch converter. Stalls around 3500 rpm. Has 1.375 crank pilot and C6 hub. Can be used with a C4 transmission with hub spline adaptor available on ebay. Has stock flexplate bolt pattern. Just back from being freshened, hasn't been used since. $400
Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears For_sa14
[img]https://i.servimg.com/u/f27/14/37/50/57/for_sa15.jpg[img/]
I have a set of 3.73's out of a 75 F-250 $50
Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears For_sa12
Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears For_sa11
Last edited by bluef100fe on June 9th 2011, 10:31 am; edited 1 time in total (Reason for editing : got pictures to show up)
bluef100fe
bluef100fe
Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears Empty Re: Garage Cleaning, Comp engineering, Rancho, Ultimate Converter, dana 60 gears
Post  dirt_worker June 10th 2011, 3:06 pm
I may be interested in the gears. How many miles and what kind of condition are they in?
dirt_worker
dirt_worker
Post  bluef100fe June 11th 2011, 9:11 am
dirt_worker wrote:I may be interested in the gears. How many miles and what kind of condition are they in?
They are in good shape they came out of a truck that had 20,000 on the odometer. I'm guessing it was 120,000 miles. They look great, have a nice pattern deep in the middle of the teeth. Let me know if you want them thanks
bluef100fe
bluef100fe
Post  514Fox87 June 12th 2011, 8:11 am
sorry thought they were 9 inch.
514Fox87
514Fox87
