hurt a head today...
+10
whitefield
Wheelie58
jones
ThndrChkn
Frank Kramer
14 posters
Hi,
We had the second pulling event for 2011 here today. New frame performed well on some bad track conditions but unfortunally we destroyed a TFS A460 10 bolt cilinder head.
Broke all the bosses from the intake stands and the exhaust stands pulled all the threads out.
Still finished on a 3th place.
Here is a video off almost the full class.
I was running last.
I was running last.
Re: hurt a head today...
That sucks Frank... That thing still sounds Awesome. Even being a "head" short. Hope you can get it fixed soon.
ThndrChkn- Posts : 2216
shaft rockers?
Tractor looks real good, hate that your suffered the damage. It appears there is a healthy class of racers.
jones- Posts : 2230
Frank,
I hate to hear about the damage. It sure sounded good.
We need to get that announcer to come to Windy Hollow Dragway.
Heck...you probably have the thing fixed already....
Keith
Keith
one of the few times you'll see that many bbf's make that much power at one time! bitchen!
richter69 wrote:shaft rockers?
Yes, WW rockers titanium intakes .904 lifters.
Think that we found the problem. Converted the heads to the titanium valves this winter, installed longer stand bolts but there were short helicoils in the heads...
Will post some pictures tonight.
Glad you found the problem Frank, but I'd bet it wasn't the kind of present you wanted for your birthday.
schmitty- Posts : 4538
sorry don't know what Happened didn't mean to post three times .
whitefield- Posts : 2244
That sucks and those pics aren't pretty! Good luck getting it back together.
Frank,
Sorry to hear about your problem, that hurts! I do agree that your problem is the short heli-coils. I've seen that before.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
The only good helicoil is one that is in the TRASH
should use Keenserts
the Coug- Posts : 3055
that would make me sick!are you gona repair the head? i would on a n/a deal but i dont know about your blown stuff.
the Coug wrote:The only good helicoil is one that is in the TRASH
Where can I find good info on the Keenserts??
They have to be at least .750" long.
http://alcoafastener.thomasnet.com/category/keenserts-reg-
http://automotivefasteners.thomasnet.com/viewitems/ls-and-accessories-thread-repair-systems-and-tools/keenserts-174-thinwall-inserts
http://www.bjg-design.com/designbook/pdfs/INS-KNS-KNS.pdf
http://www.newmantools.com/kee.htm
http://www.thorintl.com/Keenserts-Keyserts-Keylocking-Inserts.htm
Frank I have changed thousands of heli coils out for keenserts, the advantage is helicoils are a piece of wire that when installed and torqued down will push the wire sideways and put force on the sides, and alot of times when you remove a bolt the heli coil will come out with it....and the side force breaks the object it is in
The Keensert is a solid steel insert with locks when installed it is locked in solid and when torqued it pulls up like it was part of the metal, not some wimpy wire trying to hold.
They come in heavy wall or thin wall in any size. I keep them in 10-32 up to 3/4" they also come in fine thread, and I think they have them in metric also....
do some looking over where you are and see you should have a place there to buy them.....
good luck
good luck
Frank, when you hurt a head you hurt em good!!
Frank Merkl- Posts : 1524
You know that is the difference between drag racers and truck pullers. Most drag racers are trying to build a 600 cid BBF on a $100 budget and truck puller guys aren't afraid to put 3 BBF's in their tractor and blow the shit out of them trying to make a full pull. Bad ass dude. Sorry about the bad luck.
jasonf- BBF CONTRIBUTOR
I don't know when the change was made but the TFS exh rocker studs now have 1.300" of underhead lenght.
Frank Kramer wrote:the Coug wrote:The only good helicoil is one that is in the TRASH
I use the FORD MOTOR COMPANY cylinder head inserts which are readily available from many sources and normally are used to thread into the thermactor holes in the ends of Ford production cylinder heads.
I have used them HUNDREDS of times for valve train stud locations of all different heads, (To even move the stud location somewhat or the stud angle as well as using them for better anchoring). They are blind and are over an inch long and are easily machinable to a shorter length if necessary. Threaded 5/8 - 11 outside and 7/16 - 14 inside.
» 572 A-Head BBF dyno today.
» Did I hurt anything
» this is going to hurt
» That's racing they say but this one hurt a little ........
» Nitrous......hahaha
