Can I reuse my Fel Pro head gaskets?
Tommyj466
DanH
Can I reuse my Fel Pro head gaskets? Empty Can I reuse my Fel Pro head gaskets?
Post  jbozzelle June 17th 2011, 11:48 am
Engine has about 30 mins of run time and 4 passes. Gotta pull the head to make sure I didn't clip the valve with the piston!
Can I reuse my Fel Pro head gaskets? Empty Re: Can I reuse my Fel Pro head gaskets?
Post  DanH June 17th 2011, 1:29 pm
I've done it before on high compression small blocks . few things that were done , same gasket on same side & head . do not clean/scrape head or block , used idianhead type sealer around water holes .
DanH
Post  Tommyj466 June 17th 2011, 2:34 pm
I've done it before. If gasket still looks good, I think you'll be OK. Smile
TJ
Tommyj466
Tommyj466
Post  richter69 June 17th 2011, 4:01 pm
I reused a set way back in the day on a grenade, worked fine...............would I advise doing it for no more than the gasket cost on your build..............no.
If it were a Cometic it would be more than fine.
Post  Lem Evans June 17th 2011, 4:38 pm
jbozzelle wrote:Engine has about 30 mins of run time and 4 passes. Gotta pull the head to make sure I didn't clip the valve with the piston!
Is it a 1018/frpp a441 or the blue stuff?
Post  jbozzelle June 17th 2011, 4:46 pm
1018's
Post  Lem Evans June 17th 2011, 4:49 pm
Like has been said.......if they look good the odds of sucess are very good.
Post  rmcomprandy June 17th 2011, 4:50 pm
If it is the same head surface and the same block surface, you can re-use the gasket if it isn't in any way structurally compromised.
Post  jbozzelle June 17th 2011, 5:02 pm
I'm out of intake gaskets and Jomar filters anyway. So I might as well pick up some new gaskets when I order the other stuff from Shawn next week. Just sucks that the local parts houses don't have this stuff.
I'll be pulling the heads this weekend. Hoping no junk went down the intake during the wreck. It's bad enough the valve cover breather got pushed into the stud girdle which caused the rocker to bind and bend the #8 ex pushrod. Hoping the valve isn't bent either
Post  69F100 June 17th 2011, 6:38 pm
John did you pull the pan and look bottom end at your bearing if it hit that hard on the valve cover it may have traved it for oil to.Just something you may want to look at to if you hadn't . If the valve did hit the piston even if it didn't hurt the piston check and make sure that rod bearing not hurt.I have seen this happen before where a valve came in contact with piston it show it ugly head later on cost me $5000 one time all the ugly crap started at the cyclinder.
Jim
Post  jbozzelle June 17th 2011, 7:21 pm
The pan, pickup and pump is getting changed to install it in the Mustang so I plan to pull some main and rod caps and see what it all looks like.
Post  longroofracer June 18th 2011, 8:05 pm
Depending on how it pushed against the stud girdle... is it possible it stressed/damaged the studs or any other related parts, since the girdle ties everything together?
longroofracer
longroofracer
