top lube for alcohol
+8
138
fe50stang
Larry Williams
Frank Kramer
johndickjr
12 posters
top lube for alcohol Empty top lube for alcohol
Post  johndickjr June 21st 2011, 9:48 am
on a alcohol motor what is the best top lube you guys are running
johndickjr
top lube for alcohol Empty Re: top lube for alcohol
Post  David Cole June 21st 2011, 9:58 am
I have tried them all. I use Klotz Uplon KL-107. It's fully synthetic and leaves less residue in the ports compared to Power Plus, etc. I used to get it from a Kart racing supply house, but now Summit carries it. I do mix it at half the recommended does. 1/2 bottle per 55 gallon drum on methanol.
http://www.summitracing.com/parts/KLZ-KL-107/
Post  rmcomprandy June 21st 2011, 11:12 am
johndickjr wrote:on a alcohol motor what is the best top lube you guys are running
With the alcohol fueled, turbocharged marine engines which run on the dyno near here, they use "Top Lube" by a company called PowerMist.
www.powermist.com
Post  rmcomprandy June 21st 2011, 11:13 am
www.powermist.com
EDIT: I wanted to edit my spelling mistakes and ended-up quoting the post. Sorry for the repeat posting.
Post  richter69 June 21st 2011, 1:15 pm
I use no lube with injection, with a carb the Klotz uplon is the best I have found, and as David said use half of what they tell ya to use.
The Redline stuff is good to.
Post  Frank Kramer June 21st 2011, 1:28 pm
Castrol R40 over here.
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
Post  Larry Williams June 21st 2011, 7:04 pm
i'v been using grape because it smells purdy
Larry Williams
Larry Williams
Post  fe50stang June 21st 2011, 7:26 pm
I use redline now. I used the vanilla kind for a while but I swapped it for no valid reasons
fe50stang
fe50stang
Post  138 June 21st 2011, 8:53 pm
www.powermist.com
I dont know about top lube for alcohol but I ran powermist racing fuels for about 4 years exclusively. good stuff
138
Post  johndickjr June 21st 2011, 10:35 pm
im going alcohol on this motor,, hope i like it..heard horry stories about milking the oil down..etc..
johndickjr
Post  cool40 June 21st 2011, 11:15 pm
johndickjr wrote:im going alcohol on this motor,, hope i like it..heard horry stories about milking the oil down..etc..
carb or injection? you may change your oil a few times to start with but when you get it tuned in it'll be fine.a vacuum pump is your best friend too and when you start it make sure you heat it up good.
Post  PaulS June 21st 2011, 11:43 pm
Is the alcohol you are going to use Methanol or Ethanol?
Their requirements are very different as far as top lube goes and what is compatible.
PaulS
Post  richter69 June 21st 2011, 11:46 pm
The ones milking the oil aint doing it right lol.
Post  Wheelie58 June 22nd 2011, 12:30 am
Power Plus from Manhattan Oil for me. I have tried others and been grossed out by the smell. pig
My pump, tank and fittings are seeming to last forever. Some of my parts have been in service since the early 1990's. I am loyal to the stuff. Summit has it for about $10.
Keith
Wheelie58
Wheelie58
Post  richter69 June 22nd 2011, 8:33 am
power plus with a carb always left a real sticky film inside the intake................not sure what caused it and never had any fuel side issues with it but that stuff it left was bothersome.
No top lube seems to work good for me......... Cool
Post  Lem Evans June 22nd 2011, 10:04 am
richter69 wrote:power plus with a carb always left a real sticky film inside the intake................not sure what caused it and never had any fuel side issues with it but that stuff it left was bothersome.
You sure you aint putting a splash of green oil in there Question
Post  richter69 June 26th 2011, 10:41 pm
I just spit on it......... Laughing
