Using oil/lube on wheel studs
Using oil/lube on wheel studs Empty Using oil/lube on wheel studs
Post  JBR-3 July 11th 2016, 9:58 pm
Last edited by JBR-3 on February 22nd 2020, 2:50 am; edited 1 time in total (Reason for editing : .)
JBR-3
Using oil/lube on wheel studs Empty Re: Using oil/lube on wheel studs
Post  DILLIGASDAVE July 12th 2016, 2:41 am
Meh, at times in the past I have sometimes used a very little amount of WD40 or PB Blaster on old abused 5/8 Drive Stud/nut threads if the nuts were a little hard to spin on by hand. But if you go crazy lubing them up it will attract dirt, and dirt will lock up the threads just like rust will.
Post  maverick July 12th 2016, 3:36 pm
I use a tiny bit of anti-seize compound on the threads only. No seizing, no loosening.
Post  whatbumper July 12th 2016, 6:52 pm
just race more and you'll have those lug nuts off and on more often. LOL
Post  JBR-3 July 12th 2016, 8:25 pm
JBR-3
Post  Gregaust July 13th 2016, 5:30 am
maverick wrote:I use a tiny bit of anti-seize compound on the threads only.  No seizing, no loosening.
Same for me Smile
Gregaust
