5/8" wheel studs
5/8" wheel studs Empty 5/8" wheel studs
Post  69F100 July 6th 2016, 11:11 am
I have had to add 1/2" spacers to keep the 31x14 from rubbing the inside. I am changing from the 1/2" studs to the 5/8" leaving at 4500 to 5000 rpm I don't want to worry about popping the 1\2" studs. I have Strange axles I have been looking at the different brands they all are in about the same price range. Just wondering which one to get and which is the best.
5/8" wheel studs Empty Re: 5/8" wheel studs
Post  cool40 July 6th 2016, 4:02 pm
Your spacer deal may work out best if you use the strange kit. It is threaded all the way down and has a sleeve that screws on with a tool that comes with them. That sleeve needs to be in the area the wheel center will be to ensure a good fit. I used moser last time and they aren't made that way. Cool
Post  DILLIGASDAVE July 7th 2016, 4:56 am
Never liked the two piece Strange stud/threaded sleeve deal, sleeves kept backing off for me. If your axles have a 5/8 thread hole then a solid one piece drive stud is the way to go IMO. If it's a bracket car use the cheaper Moser stuff, or if you got big power use the pricy Mark Williams stuff.
Post  69F100 July 7th 2016, 3:21 pm
It is a Ranger ext cab 2940 with me in it runs low 6's might go high 5's if it ever cools back off some. I haven't had it back to the track after the front end chang and went from 1050 carb to a 1800 cfm tolit. I can have the axles machined to whatever studs I go with.
