Which ARP flexplate bolts do I need?
+6
DFI429
10 posters
Which ARP flexplate bolts do I need? Empty Which ARP flexplate bolts do I need?
Post  jbozzelle March 29th 2010, 2:34 pm
I have a JW Wheel, the older one that is flat, not stamped looking like an OEM unit. What part number ARP flexplate bolts do I need? Will the ARP 2901 work?
Which ARP flexplate bolts do I need? Empty Re: Which ARP flexplate bolts do I need?
Post  bruno March 29th 2010, 2:42 pm
i know the arp bolts i ordered for my deal didnt work .... i went with some grade 8 fasteners and used all six mounting holes
http://WWW.CKRME.COM
Post  jbozzelle March 29th 2010, 2:48 pm
I would hope you used all 6!
You talking about converter to flexplate? I'm talking about flexplate to crank bolts...
Post  the Coug March 29th 2010, 2:53 pm
John check the flang thickness and let me know I have a set out of a rearend setup kit that are 7/16 fine when I get home I will check and see if they will work......they were to short for the rear end and I think they are just about right for fly wheel bolts....
Post  bruno March 29th 2010, 2:59 pm
jbozzelle wrote:I would hope you used all 6!
yes i used the arp's for the flex to the crank ( all six ) but i used grade 8 from the convertor to the flex ( and yes all six) Very Happy
thxs for clearing that up John
Post  richter69 March 29th 2010, 3:55 pm
I used the ARP's for the manual trans flywheel, just had my buddy cut them down as they were too long.
Post  jbozzelle March 29th 2010, 3:59 pm
Thanks guys. I know the ARP ones in the catalog are listed as .680 and 1.00 long on 2 different pages. Flexplate page lists the length as .680 and the flywheel page lists the length as 1.00, go figure...
I'll measure everything up and let you know how thick it is Randy. I do remember a thread on the old site years ago about the bolts being too long and messing up the thrust bearing, etc...
Post  DFI429 March 29th 2010, 6:18 pm
jbozzelle wrote:Thanks guys. I know the ARP ones in the catalog are listed as .680 and 1.00 long on 2 different pages. Flexplate page lists the length as .680 and the flywheel page lists the length as 1.00, go figure...
Flywheels are thicker at the flange than flexplates Wink
DFI429
DFI429
Post  jbozzelle March 29th 2010, 10:55 pm
I understand that Very Happy , but ARP lists the same part number with 2 different lengths. Must be a misprint somewhere...
FWIW, I measured tonight. The flexplate is right over .350 and the crank flange is right over .550 so would the .680 be too short and not have enough engagement into the crank flange? Or should I get the 1.00 lengths and cut them down? Is there a shim that I can buy and stick between the bolt head and the flexplate to take up the slight difference? If so, will that shim interfere with the converter adapter?
Post  cool40 March 29th 2010, 11:03 pm
i used some mr gasket flywheel bolts for a bbc.i had a tci that was the thick one with the extra ring on it,probly 1/4 inch thick. Smile
Post  jbozzelle March 31st 2010, 11:33 am
Think these would work out OK?
http://www.jegs.com/i/ARP/070/350-2802/10002/-1
They are .925 long. The thickness of the flexplate and crank adds up to .900
Post  69F100 March 31st 2010, 9:22 pm
I had to use the .680 arp 12 point in mine 1.00 was to long will go all the way through and hit.I thought that because the new flex plate was thicker I needed the longer ones but that was not the case.So I put the .680 in and used a drop of loctite on them.
Jim
Post  racnrick March 31st 2010, 10:23 pm
jbozzelle wrote:Think these would work out OK?
John,
I believe I have a set of these at home. They are from my old TCI flywheel, my new ATI flywheel set up came with new bolts. I'm at work right now, but I can measure them in the morning and see what length they are.
racnrick
Post  jbozzelle March 31st 2010, 10:48 pm
Thanks for the help guys. I just got off the phone with the Coug. He's got a set he's going to send to me. He's got a set of ring gear bolts that are the right length.
That right there is what this place is about!
Which ARP flexplate bolts do I need? Empty JW Wheel
Post  Wheelie58 April 3rd 2010, 8:31 am
It sounds like you got the bolt part number handled.
There is one more little detail to look at on your JW Wheel.
The ARP (Pro Series) fastener has a nice radius under the bolt head, where the bolt shank meets the head. The JW Wheel has a clean, square radius at the bolt hole edge. You may find a conflict that makes it neccesary to put a slight chamfer on the bolt hole in the Wheel to provide clearance for the ARP radius.
It is an easy detail to overlook, but the bolt head radius hits the Wheel before the flat portion of the bolt head.
I told the JW folks about it several years ago, but it looks like it never changed. I have chamfered all of my JW Wheels.
Just wanted to share that, and maybe save someone a little grief.
Thanks,
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  342g April 3rd 2010, 8:43 am
That is exactly what I'm using, been using them for last five years, just put a good coat of loc-tite on, and tighten them down good.
342g
342g
Post  jbozzelle April 3rd 2010, 1:03 pm
Thanks for the heads up Keith. What do you use to do that with? Just a typical chamfer bit?
Harold, Coug had some that measured .915 or so. I should be good to go.
Post  jbozzelle April 5th 2010, 10:35 pm
Hey Coug. Got the bolts today. Thanks again. Cold one on me next time we meet up.
Post  the Coug April 6th 2010, 6:45 am
N/P John just trying to help of a fellow BBF Bud.....
John did you get my Message on the 1st on how many Foam peanuts you can get in a 1'x1' Box.......?
hope that car runs like a bat out of H3LL...
Post  jbozzelle April 6th 2010, 9:55 am
got your message... but all I got in the box was paper towels...
