New CSR Flexplate
+13
DGS
dirt_worker
powerstrokeace
10SHOTS
Barney
56Tbird
ToddB
Wheelie58
17 posters
Page 1 of 2
Page 1 of 2 • 1, 2
New CSR Flexplate
After my recent post regarding flexplate failures, I had lots of good recommendations for replacements. The Mezeire and Reactor units looked good, but I did a little more checking. I called my old racing buddy Rowland Wood at CSR Performance and discovered that they have a new 429-460 flexplate that was not in their catalog. The one in the picture below is a part number CSR 220 AL, selling for approximately $290.
I like this one due to many factors, including the method of ring gear attachment. No welding.
If I screw up and damage a tooth, I don't have to scrap the wheel, and can just bolt on a new gear.
The price was reasonable when looking at the other opotions in that quality range.
It has an aluminum center that is just under 3/8" thick and is 1/4" thick at the crank flange.
This just gives the BBF racer another choice whan shopping for a flexplate.
I will wait until after the Bash to install it so you all can check it out while I am there.
Keith
Keith
Re: New CSR Flexplate
First I'd heard of it Keith. I also like the replaceable ring gear. Good idea.
Nevs- BBF CONTRIBUTOR
Nevs,
The replaceable gear was a big plus to me. The Reactor also features a replaceable gear, but uses welded tabs, instead of a direct flange bolting design. I am sure the old '58 will give this one a workout and test the design.
Thanks,
Keith
Thanks,
Keith
Wheelie58 wrote:Nevs,
Thanks,
Keith
Keep us posted on how it works Keith. Looks like a nice piece.
Keith,
Thanks for the heads up on the new CSR flexplate, I ordered one today for my new engine I am building. They said they have them in stock at CSR.
Todd
Todd
ToddB- Posts : 35
Todd,ToddB wrote:Keith,
Todd
When you unwrap it, you will be smilin'.
Thanks!
Keith
Just ordered my new flexplate
56Tbird- BBF CONTRIBUTOR
I think thats the one Lem told me about awhile back, I'll be getting one soon.................not that my JW has give me any issues.
That's what I have on my car , it's a awesome piece for sure, one of the best investments I've made.richter69 wrote:I think thats the one Lem told me about awhile back, I'll be getting one soon.................not that my JW has give me any issues.
It's proven to be good for 9500RPM thenBarney wrote:That's what I have on my car , it's a awesome piece for sure, one of the best investments I've made.richter69 wrote:I think thats the one Lem told me about awhile back, I'll be getting one soon.................not that my JW has give me any issues.
Coug prolly designed it......................
Either that or someone stole it from him
And then some....the alky will make it live.56Tbird wrote:It's proven to be good for 9500RPM thenBarney wrote:That's what I have on my car , it's a awesome piece for sure, one of the best investments I've made.richter69 wrote:I think thats the one Lem told me about awhile back, I'll be getting one soon.................not that my JW has give me any issues.
10SHOTS- Posts : 587
Just don't hurt their feelings by asking for contingency monies. $$$
Curt- Posts : 2791
flexplate
just odered one up.
flex plate
this is one bad azz flex plate , just make sure you order the bolt kit with it. it has both chevy and ford converter bolt pattern and looks sweet. every thing fits perfect
What converter bolt pattern are on them?
Ace
Ace
powerstrokeace- Posts : 1496
Got my CSR aluminum plate in. Nice piece.
For the guys that use one:
Do you use washers under the flexplate to crank bolt heads? Never used them with a steel plate, this alumnium seems to be very hard, but I don't want to gall it up when I tighten the bolts. Without washers my ARP flexplate bolts go through the plate about 7/16".
Same question for the converter nuts/bolts. On the engine side where the nuts for the converter sit, the flexplate is milled out to about 1/2 thickness so the nut sits down in a recess. Washer or no?
[quote="David Cole"]Got my CSR aluminum plate in. Nice piece.
Same question for the converter nuts/bolts. On the engine side where the nuts for the converter sit, the flexplate is milled out to about 1/2 thickness so the nut sits down in a recess. Washer or no?[/quot
CALL CSR AND SEE WHAT THEY SAY
ACE
ACE
Ive never used a washer on the bolts , had it on and off atleast 4 times and no signs of damage, they send washers for converter bolts
If i remember correctly when i purchased mine, he stated it required arp flexplate bolts (which i already had) and the arp hardened washers under the convertor bolts.
Not sure they have it on their website but a quick call to them could confirm the hardware they recommend.
Side note....the biggest reason i switched from the chromo CSR to the 2 piece alum unit was cause they wont recert the Steel plate...yet will recert the alum one time if its in acceptable condition. Nobrainer for the money if you need a plate w a current cert.
dirt_worker- Posts : 535
powerstrokeace wrote:David Cole wrote:Got my CSR aluminum plate in. Nice piece.
ACE
You always use Washers under nuts and bolts, they are there for a reason they cushion the bolts and keep them from breakage
the Coug- Posts : 3055
Page 1 of 2 • 1, 2
Page 1 of 2
