New CSR Flexplate
+13
DGS
dirt_worker
powerstrokeace
10SHOTS
Barney
56Tbird
ToddB
Wheelie58
17 posters
Page 2 of 2 Previous  1, 2
New CSR Flexplate - Page 2 Empty Re: New CSR Flexplate
Post  DGS August 31st 2015, 1:56 am
the Coug wrote:
powerstrokeace wrote:
David Cole wrote:Got my CSR aluminum plate in.  Nice piece.
For the guys that use one:
Do you use washers under the flexplate to crank bolt heads?  Never used them with a steel plate, this alumnium seems to be very hard, but I don't want to gall it up when I tighten the bolts.  Without washers my ARP flexplate bolts go through the plate about 7/16".
Same question for the converter nuts/bolts.  On the engine side where the nuts for the converter sit, the flexplate is milled out to about 1/2 thickness so the nut sits down in a recess.  Washer or no?[/quot
CALL CSR AND SEE WHAT THEY SAY
ACE
You always use Washers under nuts and bolts, they are there for a reason they cushion the bolts and keep them from breakage
In certain applications you need washers but saying you always need washers under nuts and bolts is not true. Washers don't cushion bolts and keep them from breaking either. If that was true wouldn't we be losing rod bolts all the time? Not saying in this instance that washers are not needed, but saying they are ALWAYS needed is not true.
DGS
DGS
Post  maverick August 31st 2015, 10:06 am
ACE
DGS, your post may have fallen on deaf ears. Wink
Post  David Cole August 31st 2015, 7:48 pm
Just an update.  Talked to CSR.
No washers on bolts that hold flexplate to the crank.   They advise to use ARP #200-2902.  ARP also says not to use washers with this bolts.  Loctite on the threads and assembly lube under the head.  Torque is 85 ft/lb.  Already had a set of these bolts and used them with my JW Wheels.
CSR said to use washers on the opposite side under the converter nut/bolt.  There is a recess machined into the flexplate that is sized that an 7/8" OD ARP 200-8532 washer snaps into place.  The washer reinforces the flexplate and makes it "think" (their word) that the torque converter bolt is 7/8"
New CSR Flexplate - Page 2 89D46456-CEC5-4DDE-82A0-6E98ACE93F73
the recesses:
New CSR Flexplate - Page 2 454550FD-935B-4567-9C7D-F3B74F1983E4
Post  bbf-falcon July 19th 2016, 4:42 pm
I busted a flexplate at Norwalk,Dan talked me into ordering one of these badboys.Got a new matching CVR starter.
Post  jbozzelle March 4th 2019, 11:02 pm
Bump. How's this piece been holding up for you guys? Will be looking into getting one soon...
Post  STR-LGL-70 March 5th 2019, 5:18 pm
I have one but haven't fired the engine in the car yet so no idea how it'll hold up, but it is well made. My only complaint is I wish the SFI sticker was on the other side so tech could see it easily.
Sheldon G
STR-LGL-70
STR-LGL-70
Post  Curt March 5th 2019, 6:03 pm
CSR is so close to going out of business, I'm not even sure Trump can save them.
Post  jbozzelle March 6th 2019, 9:53 pm
Curt wrote:CSR is so close to going out of business, I'm not even sure Trump can save them.
Why do you say that?
Post  Curt March 8th 2019, 8:45 pm
After Daryl Goza quit machining their stuff, they've had a hard time finding someone that could build quality and uphold standards.
Post  jbozzelle March 12th 2019, 8:11 pm
Gotcha. What are some other options then? I'm not going to spend money if replacement parts for this thing are obsolete...
Post  Curt March 12th 2019, 10:24 pm
Goza quit a long time ago. These are probably made somewhere overseas.
