BBC connecting rod offset
BBcomet
BBC connecting rod offset Empty BBC connecting rod offset
Post  BBcomet June 25th 2011, 4:05 pm
Can someone please explain the BBC offset on the current 2.2 rods available. Is it the big end or the small end? I have done a search and can't find a clear answer and if it's a problem. I have the crank and i'm ready to buy the rods.
Thanks in advance for your time.
BBcomet
BBC connecting rod offset Empty Re: BBC connecting rod offset
Post  richter69 June 25th 2011, 4:35 pm
big end, not a problem
Post  BBcomet June 25th 2011, 4:50 pm
Is the big end machined off center of the beam?
BBcomet
Post  QtrWarrior June 25th 2011, 5:02 pm
Yes. it is, by .060" or so.
QtrWarrior
QtrWarrior
Post  res0rli9 June 26th 2011, 12:25 am
Lem Evans sales some real nice on Ford center rods Cool
Post  dfree383 June 27th 2011, 11:22 am
res0rli9 wrote:Lem Evans sales some real nice on Ford center rods Cool
X2 some real nice oliver parts A++++ Stuff.
Post  LivermoreDave June 27th 2011, 12:26 pm
Some of the SBC applications are the same. I found it odd that an offset beam (relative to the crank-pin) was not considered offset! I exchanged the "standard rod" for an (so-called) offset SBC application with the beam centered in relation to the crank-pin. It seemed to make the rod/piston appearance much more pleasing. My experience was found while mating SBC rods to a Ford 351W crankshaft.
Dave.
LivermoreDave
