1971 429 temperature
I have a 1971 429 Cobra Jet that is running what I believe to be too hot. What is the normal running temp for this motor?
Tobycohn- Posts : 7
Re: 1971 429 temperature
What is it running at? Have you tried a different Gauge? What the Outside temp / conditions your running in?
The temperature outside is around 100. Right after I posted the question I thought about switching the gauges to check.
Tobycohn- Posts : 7
What temp. is the motor running at????
res0rli9- BBF CONTRIBUTOR
The problem is the 100 degrees outside.
Try some water wetter.
» oil temperature
» engine temperature
» looking for good 429-460 engine core to rebuild
» value of 1971 429 SCJ
» Oil Pressure and Water Temperature
