oil temperature
oil temperature Empty oil temperature
Post  cooter May 14th 2012, 9:27 am
is 140 degrees oil temp to cold on a jet boat running 5000 rpm for 45 minutes at a time? Water temp is 170, running amsoil 20/50. Oil pressure is 50 when warm
cooter
oil temperature Empty Re: oil temperature
Post  dfree383 May 14th 2012, 9:33 am
I'd want to see it about 180-190, it will make more power.
Post  cooter May 14th 2012, 9:51 am
never thought i would have to build an oil warmer Laughing anyone have any suggestions on how to warm the oil?
cooter
Post  dfree383 May 14th 2012, 10:58 am
can you put a closed loop cooling system on it?
Post  jbozzelle May 14th 2012, 12:06 pm
What's it got for cooling? Heat exchanger setup or straight raw water cooling?
Post  cooter May 14th 2012, 5:40 pm
it has an exchanger closed loop system
cooter
