4.3 Stroke Discussion
+13
Mr.
'65 T-BOLT
Diggindeeper
Barney
17 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
using an A-460 intake
what if i made some adaptors and somehow used an A-460 intake . would it be even worth the trouble
10SHOTS- Posts : 587
Re: 4.3 Stroke Discussion
10SHOTS wrote:what if i made some adaptors and somehow used an A-460 intake . would it be even worth the trouble
No the TFS Mafia will peak almost the same as the A manifold.
IDT-572 wrote:10SHOTS wrote:what if i made some adaptors and somehow used an A-460 intake . would it be even worth the trouble
and where is that? (TFS-A460)
138- Posts : 1593
Close to 7000
[quote="IDT-572"]Close to 7000[/quote
Will go higher.....
Will go higher.....
I turned my 562 to 7600 rpm with 486 gears at the nmra event last year. I lifted at about the 1000' beams because it bent my windshield braces about 2 " back , it clocked a 6.65 et at 1000' . I am not saying it was pulling 100% at that rpm , but it was still pulling some . The car had been 165 mph 2 times on 1/4 mile passes with Charlies 533 and did not bend the windshield braces.
I don't think you could get a better manifold unless it was a custom sheet metal or something like Blake done to his , which is going to cost you some $$$ either way.
KY JELLY- Posts : 1530
we gonna find out if the Snake mod is as effective on a Mafia unit here soon...........
Lem Evans wrote:I'd think we'd need to get over the 'VICTOR' thing and move on.
The so called 'mafia' tfs thing is much better than a ported vic. thing.
J.Y. Kelly's 562" deal :
951Hp @ 6,700 RPM
951Hp @ 6,800 RPM
951Hp @ 6,900 RPM
951Hp @ 7,000 RPM
It should have been pulled higher i.m.o. Not that I think It'd made more....just to see how it was past peak.
So where did the above engine peak 6,700 or 7,000? I.m.o. what one does not need is the Victor power curve where this engine could peak at 6,600-6,700 RPM and then fall off the map.
Based on J.Y. Kelly's dyno numbers it looks like the engine got happiest at 6,700 and kept on trucking. J.Y. says he has ran the engine to 7,600 with reasonable results which indicates he's deal can/will run good past peak....i.e. not fall off the map.
how did we go from cranks to intakes?
BOSS 429- Posts : 2372
BOSS 429 wrote:how did we go from cranks to intakes?
well this thread turned out better over here than my 4.3 -4.5 thread over "there"...
138- Posts : 1593
They are not that far apartBOSS 429 wrote:how did we go from cranks to intakes?
But they do very different things........ So close together, yet soooo different......Lem Evans wrote:They are not that far apartBOSS 429 wrote:how did we go from cranks to intakes?
» GoPro Discussion
» 4 Doctors having a discussion......
» stroke
» Main and Rod bearing discussion
» E4OD converter discussion -- 1,000 FWHP
» stroke
Page 3 of 3
