Alcohol Questions
Diggindeeper
Alcohol Questions
What is the approximate lowest compression ratio where alcohol (methanol) is practical? is 12.5:1 too low?
Diggindeeper- Posts : 800
Re: Alcohol Questions
I know a guy that ran his on Alky @ 9 1/2 comp
the Coug- Posts : 3055
People Run E85 on 9:1 motors all the time. Its just below what the fuel can be used for.
have ran it on 9-1 compression with great results............you will be fine
Thank you.
But are you guys running the alcohol through a carb or injected? I've always been told that running alcohol through a carb with lower compression really doesn't gain much. It's the alcohol injection setups that really make the best use. I have no clue if this is correct or not, just what I heard, so if I'm wrong please school me
kjett- Posts : 1169
Mechanical Injection.
on the lower comp stuff we used carbs, bigger gains were had.
» What do I need to do to get this thing to run 10.0's? Sorry long post.
» 500 inches on alcohol
» Alcohol injection
» Alcohol injection
» Alcohol???
» Alcohol injection
» Alcohol injection
» Alcohol???
