Art Carr Servo clearance (same as Sonax?)
I have an Art Carr Servo that looks identical to the Sonax ones. The piston is tight in the bore and I think it may be causing my 2nd gear flare. Bore inside diameter is 3.501. Outside Diameter of the groove where the O-ring sits is 3.281" for .110" per side total for the nominal 1/8" diameter O-ring which measures .117" vertically and .128" horizontally (Its flattened out in the groove). How much should I turn down the groove?
512Fairlane- Posts : 694
Re: Art Carr Servo clearance (same as Sonax?)
It's in here, Frank tells how much to cut it.
http://www.460ford.com/forum/showthread.php?t=113120
res0rli9- BBF CONTRIBUTOR
Thanks. I had seen those where he says to cut .007" deeper or .014" off of the diameter, but then in another post he says you want to compress the O-ring .005". If I take out .007" I won't be compressing the O-ring at all because I'm compressing it .007" now (.117"-.110" = .007"). So I'm still a little confused. Do I take out .007" per side or just .002" to get to .005" compression?
take the .007 out and you'll be good to go.
Was a while ago but pretty sure i only cut .007 from the diameter and piston slid in nice , didn't need to go more .
Gregaust- Posts : 626
just pm Frank, he will get you fixed up
» McMaster Carr
» Art Carr 9.5" Converter (C-6)
» Old Art Carr valve body
» Art Carr C4 Transbrake V-Body ?
» Why is my c6 servo like this?
