rocker girdles?
rocker girdles?
was looking at Jomar,1145 for iron heads.
and what NUTS i need.. its says by the way it looks to me i would need 2.2 long nuts...
are these good? and is that the right nuts? with roller rockers and are there any rockers that work better with these girdles?
racinghabbit- Posts : 575
Re: rocker girdles?
Jomar is an excellent product. Not sure on the nuts, which head are you using?
Nevs- BBF CONTRIBUTOR
Re: rocker girdles?
2.200" is correct for the 1145s. The Jomar adj. nuts are good made in the USA stuff.
Re: rocker girdles?
Get the American made ones from Jomar, the are centered right, machined correctly and hardend properly, the Chinese junk floating around is absolute crap compaired to the real jomar ones.
Re: rocker girdles?
Don't the Jomar's come with the nuts in the pack?
jbozzelle- Posts : 3705
Re: rocker girdles?
jbozzelle wrote:Don't the Jomar's come with the nuts in the pack?
Their are a couple of Vendors out their that only buy the Girdles for Jomar and than sell cheap chinese locks with them as a "Kit"
if you get the stuff from a reputable Jomar dealer you will get all Jomar parts.
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» need one rocker arm.....
» shaft-rockers
» A-460 rocker ?
» shaft-rockers
» A-460 rocker ?
