direct drum drain holes
manofmerc
cooter
what is the deal with direct drum drain holes, what do they do, why do some trannys get drilled and others dont?
cooter- Posts : 220
Re: direct drum drain holes
cools the clutches and cools the 2nd gear band
Frank Merkl- Posts : 1524
should all c6s have the drum drilled or just certain applications? Thanx for the help
cooter- Posts : 220
depends if you want the trans to last
drain holes in clutch drum
I purchased a drilled clutch drum from broader performance .It gave me the best 2-3 shift I have had .I had to go through my trans and new clutchs seals etc. were used .The only other thing was this drilled clutch drum .It had a better shift than before ..And they arent expensive either .$80 without shipping .And as Mr.Frank says .Everything runs cooler .Doug
manofmerc- BBF CONTRIBUTOR
thanx for the help, i have phoned broader a few times but no answer, ive left a message with no return phone call. I will buy a drilled drum from PATC.
cooter- Posts : 220
I hope you have a little time on your hands. It took PATC 3 weeks to send me a Fairbanks "R" servo that was in stock and thats with "expedited" shipping. I sent 3 separate emails with no response so I called and I was told "I don't know why it hasn't shipped yet but we'll get it out, hopefully tomorrow" two days later I recieved it. Good Luck... Todd
aquartlow- Posts : 169
cooter wrote:thanx for the help, i have phoned broader a few times but no answer, ive left a message with no return phone call. I will buy a drilled drum from PATC.
COOTER
Try jay again. He's been real busy and purchased the remains of Art Carr in Texas (not sure if at was parts or equipment). He's been busy moving all that stuff and getting settled in. I've had a TCI valvebody down there for 3 weeks and he called late friday(5:30 pm,he closes at 12:00 on fridays) and left me a message that it was in need of a lot of work and explained why i was burning up my trans in 4 runs. He's a 1 man shop and his quality is top notch.
Ace
powerstrokeace- Posts : 1496
thanx for the info, i will try Broader again.
cooter- Posts : 220
Your only 4 1/2 hours from Frank Merkl in Brooks, he's the guy that can help you with all your C6 issues, call him.
racnrick- Posts : 462
cooter wrote:thanx for the info, i will try Broader again.
I've dealt with Jay a few times always found him very good ..
Gregaust- Posts : 625
i talked to Frank already, he is definately a c6 master however i dont want to bother him all the time either. I just need to order all my parts and put this tranny together. I sure do appreciate all the help and good info on this site.
cooter- Posts : 220
» Broke forward drum after mig welding the peanut holes solid.
» Billet aluminum c6 direct drum
» C6 Billet aluminum Direct drum
» C6 direct drum stackup question
» Billet Aluminum C6 Direct drum
