C6 direct drum stackup question
Working with a 3 disc drum, with added snap ring groove. I've had decent service life from 4 clutch setups on these, but wanted to go to 5 and see if we find a difference in wear time. Using .077 steels, the 5th steel sits ~.070 under the lower ring groove. Seems like a potential issue when looking at it. One way to know is try it, but thought I'd get input and find out if I'm overthinking things. Looking at it, I'd worry the steel would hang in the groove. Any input is appreciated. Thanks!
J.Toney- Posts : 398
Re: C6 direct drum stackup question
Here's Franks instructions and how I have done several. Only difference I do is use a .080" grooving tool. Reduce the distance up a little if you want less clearance .
The clearance you have is plenty. With a .078"friction on top of the last steel, it would near have to totally disintegrate before the steel hits that groove , and by then you got bigger issues than the steel hitting the groove
Factory 3 clutch Drum
Using an .125” wide cutting tool register the tool in the original snap ring groove on the outer most edge as a starting point
-Bring the tool out towards the open side of the drum
- when using factory thickness clutches and steels ( .078” each) 5 of each move the tool out .345” and cut new snap ring groove , This should give you a clutch pack clearance of .060”- .065” with the standard .078” snap ring
- when using Red Alto Power Pac clutches and Kolene steels (.061”) 6 of each move the tool out .300” this should give you a clutch pack clearance of .072”-.078” with the standard .078” snap ring
There are no Modifications required to the factory .342 thick Pressure plate
Gregaust- Posts : 626
J.Toney likes this post
Thanks!! That's legit, hard to get to the groove unless the friction burns. But it looks sketchy by eye to me. I've read its done plenty, but no pics to see and haven't actually tried. I punted and used a factory 4 clutch with a cut pressure plate. But I'll do as suggested on a 3 disk in my own build first and see how it fly's.
I was in the same boat. I did the stack up before cutting. I did use the thick steel they send with the powerpacks to give a bit more "grab" length. Now the friction sits where the old snap ring was. Like you it looks sketchy but I have most if not all of the steel engaged in the drum. If you wear enough to pop it out you have more issues to work to do.
paperman- Posts : 88
Don't use the thin steel that comes with the power pack as it will bend as it's way to thin ,use the factory 3/8" thick pressure plate
Frank Merkl- Posts : 1524
» Billet Aluminum C6 Direct drum
» Billet aluminum c6 direct drum
» C6 Billet aluminum Direct drum
» direct drum drain holes
» C6 1.400 direct springs
