C6 1.400 direct springs
C6 1.400 direct springs Empty C6 1.400 direct springs
Post  J.Toney August 30th 2023, 6:22 pm
Does anyone have a good supplier for the 1.400 direct spring? I though I it somewhere years ago. Gonna run low on cores eventually!
Or a recommendation of reputable spring suppliers?
J.Toney
J.Toney
Gregaust likes this post
C6 1.400 direct springs Empty Re: C6 1.400 direct springs
Post  supervel45 August 30th 2023, 7:48 pm
J.Toney wrote:Does anyone have a good supplier for the 1.400 direct spring?  I though I it somewhere years ago. Gonna run low on cores eventually!
Call Jay at Broader.
The common Late model spring with the thick wire is what I assume you are after.
I believe  these are the ones your after, the stiff ones. Not sure if the seller has them listed correctly ( I believe they are though ) as some of the early Hipo's had a light spring (Short Ones are Light I believe) with all the spring pockets filled (18), instead of the partial count.
https://www.ebay.com/itm/235025601607?epid=1323587929&hash=item36b89e1447:g:44MAAOSwGtNkb6UM&amdata=enc%3AAQAIAAAA4BgKCb%2BRuMv%2BY4UKGQpGRVyommag%2BXU3XXMjBygafiEPlH9tUiSc%2BJtX9tGnVmPfx6nFCnikHT9wYb8P5Z2PvHn404BNubSBTEHT7I8EaOyJ2A7SYnbe%2FTybVij2QgLBM1%2Bu1cRvaEMgAqd1p%2Be1UqHtLA1mSO4CBsQD1Mron%2Bza0rPsTfHdMGTgniNDzrOhRX6NiqgX3OwbLebCf3OyYZh857dByufIAyOvzYv1TQgUmIM7G9sXkyqNahncUajSc7Pg5bkYzncEyJjKenFwrhLy9zgD8XlkqWXKvBQW7jhY%7Ctkp%3ABk9SR5qd8IzJYg
Post  Frank Merkl September 21st 2023, 8:33 pm
all I get are from core transmissions
Post  Gregaust September 22nd 2023, 3:51 am
I just bought from that Ebay store linked. He actually lists as a set of 10. Still in transit so fingers crossed all ok . Not a cheap exercise to have sent here Sad
Be very careful some of the eBay places don't specify a full set of 10 but the picture shows box of 10 on the label in pic.
Two that I contacted the price was for 1 spring individually.
Unfortunately, we do not have to luxury of spare cores to rob from: cry:
Gregaust
J.Toney likes this post
Post  J.Toney September 22nd 2023, 5:35 am
I'd hope or willing to bet there is an aftermarket supplier that has them, but I need to put in the leg work. IN A PINCH, I did substitute 4R100 direct springs. They are very similar in size, and one 4R100 direct retainer can supply springs for two C6's.
J.Toney
J.Toney
Post  supervel45 September 22nd 2023, 6:41 am
J.Toney wrote:I'd hope or willing to bet there is an aftermarket supplier that has them, but I need to put in the leg work. IN A PINCH, I did substitute 4R100 direct springs. They are very similar in size, and one 4R100 direct retainer can supply springs for two C6's.
A Couple of Tips on These and Other Small Spring's Like Them.
1. Measure The Diameter.
2. Measure The Wire Thickness.
3. Note The Coil Pitch.
4. Same With The Length.
5. If You have Valve Spring of Lighter Spring Tester Use it and Note Open and Just Before Coil Bind Pressure.
Your Can Buy Long Spring Coil and Cut To Length.
Also They Sell Assortment Packs.
When You Find The Part # of The Type Needed You Can Buy Just That in Small or Large Quanities and make them fairly Quick and Cheap.
Check Your 4R100 Springs For Weight Also.
Then Try Different Combo Count's To See if You Can Match The OEM Weights with 1 Added or Subtracted.
To The Down Under C6er I Hope So Too. At Least They Maybe OEM Mother Ford NOS. Cool
PS:1 The HangUp To Making Them MayBe You Cannot Duplicate The Tight Roll on Each End Though and May Be Best To Find A Good Source and Pay the Piper. Wink
PS:2 I Just Saw This. It Claims OEM Parts and On Vacation Until 9/26/2023 From His Link. Let Us Know Please How The Parts Do and Compared to a Stock One.
https://www.ebay.com/str/aaaaautomotiverarenosoemparts?_trksid=p4429486.m3561.l2563
Post  supervel45 September 22nd 2023, 7:23 am
^ This Popped Up on The Feed about The C6 Spring.
Another City Here. Half The Price With The Picture of The Ford Box Containing The Springs.
I Don't Know if The Company is Linked?
I Have Never Used Them Either.
I Do Know On Our Local Parts Hot Lines are Linked. I Would "Ass/ume" They Maybe State Wide?
I Will Pass The Link Along but, AS Away's Buy/Shop at Your Own Risk and Be Careful!
The AI Scams Are Out of Control and It's Even Worse Then That. I Will Just Skip Commenting on The Later of The Previous Sentence for Now!
Below is The Pop Up FleeBay Link From This Morning.
https://www.ebay.com/itm/386120258983?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3D2a6aa54c18f940119724bf03b772fc26%26pid%3D101506%26rk%3D1%26rkt%3D25%26sd%3D235025601607%26itm%3D386120258983%26pmt%3D0%26noa%3D1%26pg%3D3458402%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecall%26brand%3DFord&_trksid=p3458402.c101506.m1851
It's Getting So Crazy Out Here I Don't Even want to Help Other Hot Rodders Anymore.
I Make 0 Profit On Any of This Shit So Why Bother. It's Really Not Worth It Now! Crying or Very sad
Post  supervel45 September 22nd 2023, 8:00 am
^ F*CK ME F*CK ME RUNNING FMR^
This What I AM TALKING ABOUT.
I LOGGED OUT and DOUBLE CHECKED THE LAST LINK ONE MORE TIME.
SO DISREAGARD IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!^^^
THEIR IS AN X ON THE BOX WHERE IT SAYS 10 COUNT!!!
IT SAY'S SPRING IN THE ADD TITTLE!!!
IT SAY'S EACH IN THE ADD!!!
I READ THE PREVIOUS POST IN THIS THREAD TWICE OR MORE.
I USUALLY DON"T MISS MUCH.
MY FIRST LINK HAD NO PICTURE OF A FORD OEM BOX.
I SAW THE POPUP AND "ASS///UMED IT WAS SOMEHOW ANOTHER PLACE AND NOT PRICE FOR EACH SPRING.
I WAS WRONG AND MISTAKEN.
SO SCREW THE ABOVE LINK AND HOPE THE FIRST LINK IS LEGIT AND IF SO CONSIDER IT A BARGIN
I GUESS FROM TEXAS. WE GOT PRICKS AND CUNT'S HERE TOO!!! Embarassed
Post  Gregaust September 25th 2023, 4:38 am
That spark surplus place was the first I tried . It turned out was per spring yes . And freight was absolutely stupid. Was like 36USD for what I thought a set , but no one spring.
I was going to order 3 sets ( which i then found out was 3 springs only) and freight jumped to 142USD.
Gregaust
Post  supervel45 September 25th 2023, 6:33 am
^ I think I may have gotten some BBF Parts from Spark once. They are Local to me or close by. Seemed Like it was a set of Fel-Pro 429CJ Intake gaskets and they had the best price.
It's too bad they are doing basically a bait and switch on those C6 Springs. I mean C'Mon Man One Spring 10 for Bucks's, I Guess the ICE CREAM Fund was Drying Up! Crying or Very sad
They do have a massive warehouse of parts though. I can't remember if they do local pickup but, it seems like it was no.
Hopefully the other place does you right. He only showing 9 sets left I believe.
I am kinda surprized they are that hard to come by.
My 460 Smogger C6 is Ready to Rock full of Pink Fluid and a TransGo 67-1&2 Shift Kit. Not as Firm  as I would Like but, It'll Do. At Least it's a Fun Cheap Toy. A 750DP Pepped it up a Little. Very Happy Very Happy Very Happy
Post  Gregaust October 3rd 2023, 3:31 am
Springs arrived today Smile Very good seller , arrived very quickly . And yes these were in sets of 10
https://www.ebay.com.au/itm/235025601607?epid=1323587929&hash=item36b89e1447:g:44MAAOSwGtNkb6UM
Gregaust
Post  supervel45 October 3rd 2023, 7:26 pm
^ Good to hear my man.
Were the springs in any kind of FoMoToCo Comany Packaging?
I was playing 460 Timing yesterday. I was running My 770VS through the water ported vacuum switch.
Apparently it stuck between ports or to the manifold side signal.
It was pulling manifold vacuum to the distributor vacuum pod at idle and running 25 plus base timing.
I hooked the pod to the Metering block ported vacuum barb and straight to the pod. Blocked the other offending factory vacuum line.
Base timing around 12 now. Total looks to be hanging around 40. I believe it may have a wide slot DuraSparkII.
I did not play with it that much yet and need to look further into it. Waiting on Fuel Parts Still.
TransGo C6 Stage II Barks Nice Second gear Scratch on Demand with 31's Tires and 3.54's, Now. Cool
The Only Thing that makes any logic to me about the vacuum line deal and the shift is the modulator signal, somehow.
Also the distributor pod is leaky when tested, but still pulled timing up with the engine running. Odd Kinda Deal
PS Edit: Just hit it with a Timing Ligh at SunDown where you can see better.
Looks like 15, 42 and 50-55 with pod vacuum.
Need to get a timing Tape. Going off Factory Balancer marks that stop at 30 and making my own to space further to 40 and past.
Post  J.Toney November 10th 2023, 6:16 am
Gregaust wrote:Springs arrived today Smile  Very good seller , arrived very quickly . And yes these were in sets of 10
Thanks, I just ordered a few sets. I'm wondering if E4OD/4R100 direct springs would fly. Visually, they look close. I have a fair amount of cores and parts.
J.Toney
J.Toney
Post  supervel45 November 13th 2023, 2:24 am
Well Did You Buy Them All Out?
Oh and By The Way, You're Welcome. Wink
Post  J.Toney November 14th 2023, 6:24 am
I bought 3 sets, so maybe. Pretty sure there were more available.  Got 3 or 4 builds in line, so stocking up was a smart option. Thanks again for the link.
J.Toney
J.Toney
