factory hp rating
factory hp rating Empty factory hp rating
Post  johndickjr July 23rd 2011, 1:59 pm
the factory hp on my motor says 360 hp 480 tq from ford...now is that very accurate or way off, motor is a 1969 429 4 barrel
johndickjr
factory hp rating Empty Re: factory hp rating
Post  69F100 July 23rd 2011, 4:35 pm
shouldn't be off over 20 to 30 hp
Post  Paul Kane July 23rd 2011, 7:56 pm
johndickjr wrote:the factory hp on my motor says 360 hp 480 tq from ford...now is that very accurate or way off, motor is a 1969 429 4 barrel
It is my understanding that the 1969 engines have closer to 325 real world horspower, as opposed to the factory rated hp claim.
Paul
Post  johndickjr July 23rd 2011, 9:15 pm
even 325 is not bad for a 42 year motor....swapping in a voodoo cam..and a rpm intake..headers...going in my cheap my bracket car
johndickjr
Post  LivermoreDave July 24th 2011, 1:29 pm
If you have the opportunity to dis-assemble a factory assembled (for the masses) Ford engine and note the specifications, it becomes all to apparent why the engines don't produce the advertised power. Although I don't think the problem of assembly is as obvious today!
Dave.
LivermoreDave
Post  johndickjr July 24th 2011, 7:44 pm
LivermoreDave wrote:If you have the opportunity to dis-assemble a factory assembled (for the masses) Ford engine and note the specifications, it becomes all to apparent why the engines don't produce the advertised power. Although I don't think the problem of assembly is as obvious today!
Dave.
i tore it down today, has c9 heads, and true flat top pistons...clean as can b inside
johndickjr
