need help rating my engine
need help rating my engine Empty need help rating my engine
Post  pickleweasel October 22nd 2009, 12:13 am
Just got my 466 built and installed into my 1971 Torino GT. Runs great, just wondering if anyone could give me an idea of the power it is making. I don't have desktop dyno or access to an actual dyno but was just wondering what I am working with. Here is my build:
Intake system: Holley HP carburetor, 830 cfm annular boosters. Blue Thunder dual pane CJ aluminum intake
Heads: Blue Thunder CJ style, stock port location, stainless valves, Harland Sharp 1.73:1 rocker arms
Camshaft: Bullet Racing Cam, solid lifter, Duration @ .050 255 Intake 263 Exhaust, Duration @ .020 288 Intake 296 Exhaust, 110 lobe seperation, .623 lift Intake .641 lift Exhaust, .028 valve lash hot intake and exhaust, Cloyes double roller timing set
Rotating assembly: Stock crankshaft, H-Beam rods, Clevite 77 main and rod bearings, Probe forged flat top pistons, 11.2:1 or 11.3:1 compression ratio, MPG windage tray
Exhaust: Hooker 7115, 1 7/8" primaries, 3" dual exhaust, flowmaster 3 chamber mufflers
As for the rest of the driveline, it has a C6 transmission, 9" rear nodular case 3.90 gears detroit locker, Moser 31 spline axles
Thanks in advance Smile
pickleweasel
need help rating my engine Empty Re: need help rating my engine
Post  the Coug October 22nd 2009, 8:37 am
not a bad combo but those Flowless masters are a big restriction.
Post  pickleweasel October 22nd 2009, 7:22 pm
that's what i figured but they were free Neutral
pickleweasel
need help rating my engine Empty hp
Post  torinojoe1971 October 23rd 2009, 1:35 pm
Around 600hp
torinojoe1971
