blemish a460 block
95lightiningguy
jesse
blemish a460 block  Empty blemish a460 block
Post  jesse July 28th 2011, 2:43 pm
i bought a blemished block from lem a few yrs ago
it works great the 1 thing wrong is 1 cyl wont go over 4.550 bore
not a prob i am only at a 4.500
but am thinking about going bigger
can that cyl be sleaved to go as big as the rest can go
4.625 or am i looking at a new block
trying to get a 620 cid
jesse
jesse
blemish a460 block  Empty Re: blemish a460 block
Post  95lightiningguy July 28th 2011, 3:09 pm
Any block can be sleeved for about a hundred bucks plus the sleeve, versus buying a new one is no contest.
95lightiningguy
95lightiningguy
Post  dfree383 July 28th 2011, 3:55 pm
Yes you can sleeve the cylinder, just make sure to sonic the rest and double check.
Post  Lem Evans July 28th 2011, 3:56 pm
dfree383 wrote:Yes you can sleeve the cylinder, just make sure to sonic the rest and double check.
"We" have the FRPP sonic sheet.....he knows where he is.
Post  Paul Kane July 28th 2011, 10:09 pm
Is your 4.500" bore used up? If so, then why not just bore to 4.53" for now?
In regards to your concerns about overboring your paticular block past the recommended oversize:
  • What's the minimum wall thickness at 4.500" and what's the exact location of that thickness?
  • How much hp are you targeting and at what peak rpm?
  • Will the engine be naturally aspirated?
Knowing what I've learned through sonic checking relative to how far I've pushed passenger car blocks, and having a good idea of the conservative criteria that Ford uses to pass/fail a sonic check of the A460 blocks, I'd venture to guess that the chances are that you'll be fine...unless you're building an engine to run blown gas to 1500 hp or something like that.
We purchased a pallet of 4 of those blocks and as time goes on the more I study the sonic check sheets of that shipment, the less I've come to be concerned about why Ford set the blocks aside. The blem blocks we have may not be 100% perfect by Ford's conservative and strict criteria, but a wall thickness that is a measely 0.016" below Ford's minimum spec (in our blocks) sure as hell ain't gonna kill any engine I'll use them for....even if I bore to 4.600" or more...most certainly not with all the rest of the overkill structural integrity built into the cylinder banks of these A-blocks, wow.
Paul
Post  bbf-falcon July 29th 2011, 7:12 am
I would like to buy another A460 block .My Question is,How much extra machine work has to be done w/Blem block on and above normal 1st run A460 block? Is it really cheaper or not,after machine work? Sorry Jesse,did'nt mean to jack your thread Embarassed
Post  dfree383 July 29th 2011, 7:24 am
No edditional machine work, its just the do not meet the ford spec for wall thickness / core shift, whick is pretty strict like paul has said.
Post  jesse July 29th 2011, 10:05 am
when i first bought this block i wasnt planning on going bigger
the class i pull in has a 530 cid rule so this block was fine for what i needed
but as most of you know already know more power can be addicting
and i am thinking about jumping to our next class
it has a 630 cid rule and i was thinking if i jump up to that class
what can i use that i already have?
another possiblity is selling my lower end and building a new one
but this block has all the machine work done and just had bigger lifters
installed incase i decide to go bigger with cam and springs ect
i am gonna shoot for close to 1200hp
might go alky or keep it gas
this might be kinda hard to do with my current A heads but i will be running
ron's or enderlie if i go alky or just get another 1250 qft and run 2 on gas
i am gonna start this build slow with on piece at a time
see what i need for a crank
hopefully reuse my 6.800 oliver rods
new set of pistons
i do have a sonic sheet and lem has a copy also
this block only has 1 cly that wont bore past 4.550
and i had a sleave put in it already we bored it to fit a 4.550 piston
when i was gonna run a set of basterd pro stock heads and rlized the pistons would not work for those heads
since there were 4 differnt set of basted heads? thats a whole nother story lol
so i went back to my tfs A heads and my old pistons
jesse
jesse
Post  the Coug July 29th 2011, 7:59 pm
Jesse I hope you are not using the same guy that built your last one cuz he is a putz if he couldn' get your deck any closer than he did where some pistons are out of the hole and some are down the holes..... Shocked you have 8 different compressions in that engine....
Post  jesse July 30th 2011, 1:34 pm
nope i wouldnt take a lawn mower to him
got the deck straightned out took it to a good machine shop
the only bad thing is it put all my pistons out of the hoile but atleast
there all the same and a thicked head gasket was used
jesse
jesse
Post  605FOX July 30th 2011, 2:05 pm
we've got 2 svo blocks with darton sleeves
605FOX
