need info on my dove c heads ...want to use solid roller cam
need info on my dove c heads ...want to use solid roller cam  Empty need info on my dove c heads ...want to use solid roller cam
Post  5pointslow August 1st 2011, 7:00 pm
what am i gonna need to do to be able to use a .640 - .700 lift cam
ive got the lifters
i know i need the heavier springs , but my valves do they need to be longer and as the guides go ??
5pointslow
5pointslow
need info on my dove c heads ...want to use solid roller cam  Empty Re: need info on my dove c heads ...want to use solid roller cam
Post  69F100 August 1st 2011, 7:50 pm
I am running dove-c heads with a .649 in .642 ex solid flat tappet not the roller but I had to cut the valve guides for the higher lift I cut them to accept a .675 lift.Plus had to cut the spring pocket to accept the heavier and larger springs.Hope this helps I bought the cutters and did all my own head work cheaper than I could get it done around here.
Post  5pointslow August 1st 2011, 10:03 pm
any idea what any machine shops charge for this idea
5pointslow
5pointslow
Post  bbf-falcon August 1st 2011, 11:49 pm
All charge differently,you will just have to make some calls.
Post  dfree383 August 2nd 2011, 7:15 am
bbf-falcon wrote:All charge differently,you will just have to make some calls.
X2 and don't forget to get New SS Valves, Stock stuff will not live at the higher spring pressures.
