Solid roller for dove headed 460
Hyperteunic flat tops with valve reliefs
Stock crank
Eagle I beams
Solid roller
Roller rockers
.030 over
Victor
850 race demon
3500 stall C6 shift kit
4.11 gear 28” tire
Ported dove heads
Stock valves
MSD ignition
I bought a mildly built 460 for my 64 Ford Galaxie. It’s got decent parts but the cam is wild for these iron heads. From what the guy says it’s a Crower stage 5 with 272/277 @ .050 690/698 108 degree lobe separation. Anyway I’m going to put a more appropriate cam back in it. Thinking a 242/248 Comp solid roller. .657/.664 lift 110 degree lobe separation. This is a street car that will be beat on pretty hard. I want it to be fast, but I know it’s not. I want to throw more cam at it but I think it is probably senseless with the heads I have?
nedceifus- Posts : 118
Re: Solid roller for dove headed 460
Put some better valves in it while youre in their
Mark Miller and nedceifus like this post
I want to but that is a slippery slope. If I buy valves it seems like I should go to a bigger valve. If I do that I am 1/2 way to the cost of a pair of aftermarket heads. I kind of want to just get by till I can afford heads… You are right though. I should.
Stock valves with those heads wont accept more than .560" lift unless the spring pockets were cut down. I like the Comps cam but it will still be big. Ive seen D0VE heads with 2.19" intakes. Longer valves by .150" will help to get good spring geometry.
Dave De- Posts : 795
Word, the cam I just took out of this motor was a Crower 272/277
With 690/698 lift & 108 degree lobe separation. He must have done some work to the heads to accept the springs that are on them. I ended up ordering a 242/248 Comp with .657/.664 & 110. Having all of the springs tested now & going to start porting the dove’s this week. Thanks for the info.
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» need info on my dove c heads ...want to use solid roller cam
» what rocker arms to buy ? Dove heads pedastals milled down solid roller setup
» Big valve ported dove heads ,solid roller camshaft ..$2000 with new studs you pay shipping
» BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
