What is the most preferred distributor (type) for street use? 545 stroker build-up
72mav
MoGreen
I am looking to finish up getting my parts to transplant my lil 545 stroker into my 1992 Notch... I"m confused with magneto pick-up.. vacuum advanced..crank-trigger..etc.. Can someone please just tell me.. What is the most highly recommended Distributor (not-brand) but type to buy for my set-up..? D3VE heads,Lunati Voodoo 61605 cam,matching valve-train etc. thank you...
MoGreen- Posts : 6
Re: What is the most preferred distributor (type) for street use? 545 stroker build-up
Ford Duraspark!, with MSD box, and FORGET about it.
72mav- Posts : 1081
X2,
Duraspark, 6AL, blaster coil, DONE.......
Greg
Greg
Greg_P- Posts : 1009
Double post....... my bad!
Carry on,
Greg
Carry on,
Greg
Come on Greg, you posted X2, that doesnt mean you have to post 2 times!
Curt- Posts : 2791
X3,I'm running the same stuff as Greg_P and it works great.
Later Mark.
Later Mark.
Mark Miller- Posts : 1959
Stock duraspark is fine if the timing curve is correct or depending on the rest of the engine, the timing advance could be locked out.
501ranger- Posts : 54
» Budget Street/Strip Stroker Build Advice w/ Existing Parts plus???
» Is the Mildon Windage tray Preferred over the Canton screen type one?
» 514 stroker build up
