Fuel Injection Conversion
oktw88
Looking for a place to convert my victor intake for fuel injection. Any place you guys recommend?
oktw88- Posts : 62
Re: Fuel Injection Conversion
Where are you in OK? You have Mike Duffy in Moore.
whatbumper- Posts : 3024
I live about 10min away from Moore and I didnt even think about him. I will have to call him.
oktw88- Posts : 62
good luck trying to get ahold of him, but if you can he is the man............
Gerald Brand in Wheatland is another that might be able to help you out 405 745 3332
Here's a place that sells the intake already converted to EFI,...........
http://www.cprparts.com/products/airfuel/spyder.html
Copperhead- Posts : 492
Another alterntive is Wilson Manifolds
I just received my TFS A460 tunnel ram that I bought from Lem Evans at BF Evans Ford and then sent on the Wilson Manifolds. The work is first rate and including the fuel rail and was all cut to my supplied injectors which are standard Bosch size 96# from RCI. I am buillding my own sequential harness from parts I bought through DIY Autotune. They have everything you need to set up an EFI BBF. I ran a batch fire EMS-Pro setup previously. All this is based on the MegaSquirt software which can do anything the expensive boxes can do at a fraction of the price.
The cost is fair compared to my last go around with a TFS single plane done locally but the execution is far better. Its not cheap, but quality never is.
CDMBill- Posts : 182
CDMBill wrote:I just received my TFS A460 tunnel ram that I bought from Lem Evans at BF Evans Ford and then sent on the Wilson Manifolds. The work is first rate and including the fuel rail and was all cut to my supplied injectors which are standard Bosch size 96# from RCI. I am buillding my own sequential harness from parts I bought through DIY Autotune. They have everything you need to set up an EFI BBF. I ran a batch fire EMS-Pro setup previously. All this is based on the MegaSquirt software which can do anything the expensive boxes can do at a fraction of the price.
Ya I was looking at running a FAST system, but i might check into the MegaSquirt. I am still needing to figure out the injector size that I will be needing. What is the best way to go about figuring out what injector i am needing to run?
Travis
oktw88- Posts : 62
Check out the Megasquirt site...they have a whole turorial on EFI...including injector sizing and stuff.
Maxx Levell- Posts : 87
Will do, ThanksMaxx Levell wrote:Check out the Megasquirt site...they have a whole turorial on EFI...including injector sizing and stuff.
oktw88- Posts : 62
» Fuel injection ???
» Ron's fuel injection $350
» Fuel Injection
» fuel injection
» Fuel Injection setup
» Fuel Injection
» fuel injection
