fuel injection
+9
bb429power
KY JELLY
13 posters
 fuel injection Empty fuel injection
Post  KY JELLY October 14th 2010, 4:59 pm
This looks like what Ky needs fer Christmas minus the electronic , but with down nozzles Very Happy
http://www.hilborninjection.com/product.asp?Id=367&CatId=176
 fuel injection 460F8.e
KY JELLY
KY JELLY
 fuel injection Empty Re: fuel injection
Post  dfree383 October 14th 2010, 5:50 pm
Ain't big enough for your motor.
Besides you'll put you eye out with one of those Laughing
Post  the Coug October 14th 2010, 6:28 pm
Randy I have allready checked with Hillborn about the setup it takes a Blue thunder Webber manifold with their butterfly bodies, and as Dave said 2 3/16 or 2 3/8 ain't gonna cut it.... I figured 2 7/8 to 3 inch should be close.....
Post  Lem Evans October 14th 2010, 7:56 pm
"with down nozzles"
Down where?
Post  bb429power October 14th 2010, 7:58 pm
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
down here
bb429power
bb429power
Post  Lem Evans October 14th 2010, 8:04 pm
bb429power wrote:vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
down here
Okay....so tell us where the downs are?
Post  bb429power October 14th 2010, 8:15 pm
down here
Beats me I was just being a smart azz. Just kidding though, I don't know much about high performance injection systems.
bb429power
bb429power
Post  138 October 14th 2010, 8:55 pm
Hilborn injection FTW!!!...Razz I would sooo run a setup like that on the right car....
 fuel injection Foxbros
 fuel injection 569a
138
Post  KY JELLY October 14th 2010, 9:18 pm
the Coug wrote:Randy I have allready checked with Hillborn about the setup it takes a Blue thunder Webber manifold with their butterfly bodies, and as Dave said 2 3/16 or 2 3/8 ain't gonna cut it.... I figured 2 7/8 to 3 inch should be close.....
I am thinking about cutting my 4150 victor up , making my own bodies , and buying butter fly's and shaft's, and ram tubes .
KY JELLY
KY JELLY
Post  c.evans October 14th 2010, 9:58 pm
Randy,
Before you do, give me a chance to call Mr. Kent Enderle and see what he can do in making a mechanical fuel injection set-up similiar to the electronic Hilborn set-up that you pictured.
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  cool40 October 14th 2010, 10:10 pm
Lem Evans wrote:"with down nozzles"
Down where?
OK,whats a down nozzle? Suspect
Post  richter69 October 14th 2010, 10:11 pm
one that aint "up"........... Razz
Post  cool40 October 14th 2010, 10:23 pm
richter69 wrote:one that aint "up"........... Razz
i'd say you run up nozzles with green HeRo oil for lube? Laughing
Post  KY JELLY October 14th 2010, 10:34 pm
Down where?
the heads are drilled from the exhaust side to the bowl area above the valve and a tube is welded or pressed in the head and the fuel nozzles comes out in the bowl just above the valve and sprays the fuel right on the valve and keeps the disturbance out of the runner in the head
KY JELLY
KY JELLY
Post  KY JELLY October 14th 2010, 10:39 pm
c.evans wrote:Randy,
Uncle Charlie
That's fine , but Blake and I were talking today if it might be better to not use a weber intake because of the abrupt turn at the head. Just keep the tubes the same angle as the port. I don't know if there is enough meat on that weber to change the angle that much ?
KY JELLY
KY JELLY
Post  richter69 October 14th 2010, 10:43 pm
why not just get some billet plates like Charlies intake adapters and fab a valley pan?
Post  KY JELLY October 14th 2010, 10:46 pm
thats a good idea Smile
KY JELLY
KY JELLY
Post  richter69 October 14th 2010, 10:49 pm
be easier to weld to than the cast aluminum as well.
Post  c.evans October 14th 2010, 11:08 pm
Uncle Charlie
Those Blue Thunder intakes are offered with the horizontal carb pad as you pictured,,,,,,and then also with a 10* carb pad so that the injector tubes are inclined more towards each other (total of 20*). That should help accomplish what you and Blake were talking about.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  c.evans October 14th 2010, 11:10 pm
Well I've got a new set of billet intake flanges here and the valley pan too. I can't remember whether or not I showed them to Blake or Randy. Crying or Very sad Shocked
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  KY JELLY October 14th 2010, 11:20 pm
you gettin that crs too lol! I don't remember seeing them , I think you showed me some adapter plates for the big heads c and profiler Smile
KY JELLY
KY JELLY
Post  c.evans October 14th 2010, 11:30 pm
What's crs? Is it the same as senile?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  the Coug October 15th 2010, 2:48 am
c.evans wrote:What's crs? Is it the same as senile?
Charlie
Can't Remember S*#t don't worry Charlie we all get it from time to time...
Randy I talked to Kinsler also if I remember and they will make one but don't ask how much....
Post  dfree383 October 15th 2010, 7:26 am
I'd do a sheet metal / billet ram and a enderle catcher set up with the down nozzels or direct injection.
Post  KY JELLY October 15th 2010, 11:52 am
I am not sure Mrs Kymustang would see that being in the budget, but I bet I could hide a fogger under all that lol!
KY JELLY
KY JELLY
