roller cam
roller cam
looking for a solid roller cam in the 680 lift range..dur XXXX ..used is ok...cheap in nice as long as its not junk
johndickjr- Posts : 896
roller cam
Hey i got one in perfect shape. Has very few pass on..specs 275-285 708-712 lift take 100.00 plus ride...
557 mazda- Posts : 101
Re: roller cam
springs i hav are only good to 690 max557 mazda wrote:Hey i got one in perfect shape. Has very few pass on..specs 275-285 708-712 lift take 100.00 plus ride...
Re: roller cam
put some 1.7 BBC rockers on it and you are in like flin
the Coug- Posts : 3055
Re: roller cam
already hav a set of crane golds bbf...the Coug wrote:put some 1.7 BBC rockers on it and you are in like flin
Re: roller cam
i have one maybe a little too small its a 630 doug herbert cam with a few runs $100 shipped
hayhauler- BBF CONTRIBUTOR
Re: roller cam
i like that..pm senthayhauler wrote:i have one maybe a little too small its a 630 doug herbert cam with a few runs $100 shipped
Re: roller cam
johndickjr wrote:springs i hav are only good to 690 max557 mazda wrote:Hey i got one in perfect shape. Has very few pass on..specs 275-285 708-712 lift take 100.00 plus ride...
Don't forget to take the lash off......
Re: roller cam
got one today
Dur Int-Exh: 280/280
Dur @ .050 Int-Exh: 240/240
Lift 1.5 - 1.5 Int/Exh:
Lift 1.6 -1.6 Int/Exh:
Lift 1.7 -1.7 Int/Exh: 640/640
Lobe Center: 110
Valve Lash: .016-.018
RPM Range: 2500-6500
Description: Street/stripperformance. Choppyidle, use 2500+stall & headers. 9.5:1 compression.
Lobe Center: 110
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» C460 Pistons+roller lifters and roller cams...
» Looking to trade a comp solid roller cam I have for a Hyd roller
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
» Using a soild roller lifter on a hydraulic Roller cam.
