You guys ever lift a complete BBF and glide by the carb pad?
+11
jcoxracing
crittersf1
manofmerc
15 posters
You guys ever lift a complete BBF and glide by the carb pad? Empty You guys ever lift a complete BBF and glide by the carb pad?
Post  jbozzelle August 9th 2011, 3:28 pm
Looking to get the engine and trans in my car tonight. You guys ever lift an BBF engine/glide combo by the carb pad with a lifting plate?
Just curious just how much those 4 little 5/16" bolts can take?!
You guys ever lift a complete BBF and glide by the carb pad? Empty Re: You guys ever lift a complete BBF and glide by the carb pad?
Post  bruno August 9th 2011, 4:05 pm
yes and with the pg to boot
http://WWW.CKRME.COM
Post  69F100 August 9th 2011, 4:20 pm
John I have lifted my 460 with iron heads and c6 by the carb pad on my motorsports g429 intake with no problems if that helps eaze your mind any.
Jim
Post  jbozzelle August 9th 2011, 4:21 pm
Thanks guys.
Post  Curt August 9th 2011, 4:27 pm
Make sure the nuts are tight! bom
Post  jbozzelle August 9th 2011, 4:31 pm
I use bolts so I can use all the threads in the carb pad.
You guys ever lift a complete BBF and glide by the carb pad? Empty lifting engines
Post  manofmerc August 9th 2011, 4:42 pm
It will be fine .I use a lift plate I made with extra holes for the lift hook .It helps whenever you install the engine with transmisson attached .My 67 comets engine compartment is kinda tight .I have been doing it this way 20 years .Good luck with your install Cool Doug
manofmerc
Post  dfree383 August 9th 2011, 5:53 pm
Do it all the time, No issues here.
Post  IDT-572 August 9th 2011, 5:58 pm
Curt wrote:Make sure the nuts are tight! bom
Mine tighten up every time I lift one that way................. Shocked Shocked Laughing
Post  crittersf1 August 9th 2011, 6:04 pm
Works like a champ
crittersf1
crittersf1
Post  Curt August 9th 2011, 6:17 pm
You guys ever lift a complete BBF and glide by the carb pad? 1lg118NutJuggling
Post  David Cole August 9th 2011, 6:25 pm
I bought one of these a little while back. Worth double what it cost! I have used it twice. Last time was to put the 598 in my Bird. Fully assembled and with a JW case (heavy!) glide attached. It combines a lift plate with a load leveler. You can tilt the complete assembly almost to 45° in either direction or level it even with much more weight on one end. $70
http://kaizen.homestead.com/Loadlevelingliftplate.html
Post  69F100 August 9th 2011, 7:14 pm
I have a long engine leveler that you have to use 2 chains one for each end of the heads but it want work for my ranger might have to build me one of them I like that better than the long one I have.
Post  jcoxracing August 9th 2011, 7:36 pm
The lift plate is the only way I have ever done it with the motor/trans.
http://www.mustangsplus.com/catalog/articles_lift_engine_08.pdf
Justin
jcoxracing
jcoxracing
Post  bbf-falcon August 9th 2011, 10:21 pm
[quote="69F100"]John I have lifted my 460 with iron heads and c6 by the carb pad on my motorsports g429 intake with no problems if that helps eaze your mind any.
X2 Many times.Complete w/ps,ac,alt.
Post  Wheelie58 August 10th 2011, 12:21 am
David Cole wrote:I bought one of these a little while back. Worth double what it cost! I have used it twice. Last time was to put the 598 in my Bird. Fully assembled and with a JW case (heavy!) glide attached. It combines a lift plate with a load leveler. You can tilt the complete assembly almost to 45° in either direction or level it even with much more weight on one end. $70
That is a nice link, David.
It shows some test data about the loads required to fail their lift device.
Cool....
Keith
Wheelie58
Wheelie58
Post  bbf-falcon August 10th 2011, 4:26 am
WOW Shocked Very Happy
Post  jbozzelle August 10th 2011, 2:17 pm
Thanks guys. I got it dropped in last night.
Post  bruno August 10th 2011, 2:34 pm
Dan Hobbs has some test data on the piece we used also Razz Razz
Post  schmitty August 10th 2011, 11:33 pm
I made my own out of 1/4" plate and I set my engine, trans, and heavy 205 cast iron T/C in all in one piece. Cool
Post  IDT-572 August 11th 2011, 9:08 am
schmitty wrote:I made my own out of 1/4" plate and I set my engine, trans, and heavy 205 cast iron T/C in all in one piece. Cool
Now that's a test.................
I have always set mine that way too until this last engine where I modified my manifold.............. Shocked
Post  '65 T-BOLT August 11th 2011, 9:12 am
I still use the redneck eastern mountain william way! chain!
'65 T-BOLT
'65 T-BOLT
Post  BigBlockRanger August 11th 2011, 9:21 am
Yes.
You guys ever lift a complete BBF and glide by the carb pad? 149230_459792369484_687514484_5351246_2907871_n
