Carb pad lift plate
rmk57
jasonf- BBF CONTRIBUTOR
Re: Carb pad lift plate
That's the way I lift mine out, even when I had iron heads.
rmk57- Posts : 176
I actually seen goofballs lift their sheetmetal intake equipped engines that way!
I prefer the cable sling that bolts to back of 1 head and the front of the other head.
10.0- Posts : 54
Lift plates are fine, make sure you have enough thread engagement and the bolts are tight. A single 5/16" bolt has over 1500lbs of load strength and there are 4 of them.
norm- Posts : 261
I’ve lifted my bbf with a C6 attached more than once. No problem.
Would do it again. Like was already been stated, The bolt shear strength is around 6k total. Make sure they are tight. No need to over tighten. Just make sure they are good and snug. An iron headed 460 with a C6 attached isn’t even 1K#. You’ll be fine.
738drvr- Posts : 600
I don’t mean to hijack the thread but...
JasonF, what intake is on your engine in the picture? It looks like the injector bosses are cast in instead of added later.
wickettoby1- Posts : 352
Looks like the trickflow 4150 manifold
norm- Posts : 261
norm wrote:Looks like the trickflow 4150 manifold
It worked great.
55-56 Ford ? I like the expandable cap on the inner fender for fresh air intake.
rmk57- Posts : 176
rmk57 wrote: 55-56 Ford ? I like the expandable cap on the inner fender for fresh air intake.
56 Mainline. The cap was cheap and easy to keep the fumes out. It's been in there for about 14 years. Eventually it will get deleted all together.
Great looking body style. Iv'e always liked the no frills versions of these cars. I have 57 Custom tudor.
rmk57- Posts : 176
» Will Miller mid lift rockers 1.8 be good for a solid roller 272 Dur. .688 lift?
» You guys ever lift a complete BBF and glide by the carb pad?
» Carb Plate Lifting
» Injector plate above or below carb spacer
» new never used trickflow a460 tunnel ram single carb top plate ....looking to trade
