Sounds like a good deal
http://www.yellowbullet.com/forum/showthread.php?t=396190
BBF 548ci
548ci
lightened Eliminator block 4.600 bore with bushed .904 lifter bores
Block no longer has motor mounts so you would need to use a plate. But who would use them for this kind of power anyways
C-460 heads
WW 1.80 rockers
BJ custom sheetmetal intake which was 20hp better than my Hogans
2 SV-1 1240 CFM carbs
New BME rods 6.665 2.100" big end
JE lightened pistons 16-1
Scat lightened billet crank
Comp 60mm roller cam
Isky Red zone lifters
Manton 7/16 taper push rods
PSI 1250 coated valve springs
Manley Ty valves
Danny Bee
Meziere Water pump
JW flex plate
Skinny Kid motor plate
GZ Vacuum pump
Product engineering 4 port regulator
New sheetmetal valve covers
Billet Fab pan for a fox body
MSD distibutor
Lexan scoop
Make 1152hp @ 8100rpm and 820ftlbs @ 6500rpm on a conservative dyno.
Ran 8.35 @ 165mph in a 3200lb 10" tire car in 4200 ft of air with a glide.
It has 4 dyno pulls and 17 1/8 mile passes. Spare parts available as well!
$16K obo or Trade?????
__________________
2008-09 WCHRA PRO-STOCK CHAMPION
BBF 548ci
548ci
C-460 heads
WW 1.80 rockers
Manley Ty valves
Danny Bee
Meziere Water pump
JW flex plate
GZ Vacuum pump
MSD distibutor
Lexan scoop
__________________
429 Powered 84- Posts : 163
Re: Sounds like a good deal
That belongs to Mike P. He's a member here. That's a sweet deal for someone IMO!!!
jbozzelle- Posts : 3705
very sweet deal indeed , if every thing is fine
» What carb spacer do i need{ 4150 victor} to help topend?
» WHO HAS INSTALLED BACK HALF KIT
» Pro Class Rules at the Bash
» Cale Aronson
» Ford bash date
» Cale Aronson
» Ford bash date
