mounting my trans cooler
I am looking for a new way to mount my trans cooler on my 68 stang. I have had it mounted to the front of the rad with the zip tie things but i wanna get it off the front of the rad.I was thinking of making some type of bracket to mount it under the front of the car. but i need some ideas. pics would be real helpful too.Show me what you have done.
Thanks Bob
Thanks Bob
mustang68mustangs1- Posts : 169
Re: mounting my trans cooler
we recently mounted one under the trunk with a fan mounted to pull air out of the car to cool the cooler.
whatbumper- Posts : 3024
have done the truck mounted deal with a fan for years with no issues, currently have one of the heat sink deals mounted to the bottom of the floor.
In my 56 I have BnM cooler with fan underneath. On other cars I have used 1/2" wide x 1/8" flatbar (or thinner) to mount the cooler to then mount that to the top/bottom of the rad.
jasonf- BBF CONTRIBUTOR
I forgot to mention that I never ever use those plastic ties. The will wreck your radiator over time making them not so cheap in the long run.
My rad guy says he has seen those ties actually saw through the rad from vibration of an elec. fan. I am using alum. flat stock to mount my fan to then spanning it from the top and bpttom rails of the rad. I was looking at the F-250's at work and they have the trans coolers mounted on an angle just behind the bumper. I might try something like that. Maybe off of the strut rod brackets.
Bob
Bob
mustang68mustangs1 wrote:My rad guy says he has seen those ties actually saw through the rad from vibration of an elec. fan. I am using alum. flat stock to mount my fan to then spanning it from the top and bpttom rails of the rad. I was looking at the F-250's at work and they have the trans coolers mounted on an angle just behind the bumper. I might try something like that. Maybe off of the strut rod brackets.
Bob
That was how my Ranger factory cooler was mounted and I reused the cooler I have it mounted up front so when the air comes through the grill it will hit it.
» Pit trans cooler
» trans cooler
» trans cooler lines C6
» You better look
» SCJ and ported C8 472'' in the works (both finally done)
» trans cooler
» You better look
