28 inch tires on Foxbody
bigblockfox468
514Fox87
Are any of you guys running 28 inch tires on the front of a foxbody mustang and do u have any clearance problems?
514Fox87- Posts : 436
Re: 28 inch tires on Foxbody
Why 28's ? Just got some one on on mine which are 25's. Did I f==- up? I have an 85 LX Hmmmm
I am having trouble going red. I have 26" inch now and and I'm redlighting with .017's. Trying to change the car instead of my routine.
Maybe leave on a lower chip.
Lower chip would be good if I wasn't footbraking. lol I leave when the last yellow lights and if I delay I'm all over the place on R.T. But if I leave as soon as I see yellow I'm red .017-.025. Wanting a taller tire so the tire stays in the beam longer. Can't lower the rpm I leave on because I leave at 2200 now.
depending on how much air is in the tires...let some out
stagger the front tires
res0rli9- BBF CONTRIBUTOR
We ran the m/t 27.5 dia on our fox, they were tight but did not rub. Sounds like a taller tire might be an easier solution for your problem, with the taller tire you can adj the tire pressure as needed as well. Softer front shock extension and more travel will also slow it down some. Increasing the front stagger can also slow down rt, but would be more a a pita IMO................
tie the front down just a little bit.
Curt- Posts : 2791
Curt wrote:tie the front down just a little bit.
more travel = slower r/t, I don't think I'd tie it down........
Yeah, but sometimes a dead lift will take more energy than a snap lift.
Curt- Posts : 2791
» MT tires
» Big Tires...
» Test-N-Tune tomorrow **video added***** another update
» Reusing tires with Rim Screws?
» 31-15.50-15 giant pullers
» Big Tires...
