Rear Main Seal
njstang87
Rear Main Seal Empty Rear Main Seal
Post  njstang87 August 15th 2011, 5:00 pm
Hey Guys,
I tried a search on this and didn't find what I was looking for. The main is leaking in the 460 we are about to swap into a mustang. My question is which seal do you recommend? It is mostly stock now. Will be doing ported heads, cam, intake, and carb in the near future. Advance has two that I was looking at. PN: 40032 & 2909. They are both felpro two piece. The 2909 says for high vaccum applications. Or should I look for a one piece. Thanks
njstang87
Rear Main Seal Empty Re: Rear Main Seal
Post  Lem Evans August 15th 2011, 6:03 pm
All are two piece.
Post  69F100 August 15th 2011, 7:42 pm
I like to offset the seal alittle when installing them I like to turn it about 1/4" so that the ends are in the block and main cap, instead of letting them touch even with the block and main cap.I have not had a main leak after my Dad told me about offsetting the seal don't know if that the way you do it or not.
Post  res0rli9 August 15th 2011, 11:37 pm
The rear main seal has crush spec., if thats not right they will also leak.
Post  bbf-falcon August 16th 2011, 2:32 pm
69F100 wrote:I like to offset the seal alittle when installing them I like to turn it about 1/4" so that the ends are in the block and main cap, instead of letting them touch even with the block and main cap.I have not had a main leak after my Dad told me about offsetting the seal don't know if that the way you do it or not.
Yea, I do the same w/good resullts
Post  crittersf1 August 16th 2011, 2:48 pm
[quote="res0rli9"]The rear main seal has crush spec., if thats not right the will also leak. [/quoe] Pay special attention to this
crittersf1
crittersf1
Post  njstang87 August 17th 2011, 10:23 am
Thanks for the information.
njstang87
