Rear Main Seal Crush
dbshelton
I have read so much on this topic that my 60 year old brain is confused. Trying to get this straight since I can't find a diagram or picture. When setting crush to do I put seal half in the main cap flush on 1 end and cut seal to where it protrudes .010 on the other side? Do same, put seal flush in the block on 1 end and cut the seal end to .010 on the other side? Is this correct?
dbshelton- Posts : 48
Re: Rear Main Seal Crush
What kind of seal are you using? I have never cut one.
cletus66- Posts : 865
If you're using a normal 2 piece seal (NOT rope) install with one side protruding about 1/4" from the block and the other with the opposite side protruding from the cap, don't cut or trim anything, just LIGHTLY deburr the ends of the seal cavity where the protruding ends will have to go "in" so the backs of the seal ends don't get shaved. No silicone on the ENDS of the seal, just a touch on the cap-to-block flat area to prevent seepage.
pmrphil- Posts : 170
I'm using a Felpro rubber 2 piece seal.
pmrphil wrote:If you're using a normal 2 piece seal (NOT rope) install with one side protruding about 1/4" from the block and the other with the opposite side protruding from the cap, don't cut or trim anything, just LIGHTLY deburr the ends of the seal cavity where the protruding ends will have to go "in" so the backs of the seal ends don't get shaved. No silicone on the ENDS of the seal, just a touch on the cap-to-block flat area to prevent seepage.
This the way I also do the 2 peace rear main seals never had a problem with one leaking so far.
I've got the Kasse one piece and hope that it works ok I should know this week.
57ford custom- Posts : 107
Measuring "crush" on a two piece, steel core, rubber type seal requires a totally different installation than when actually building the engine with the seal ends offset...
Two much "crush" is just as bad for leakage as not enough. One side of each half, I have protrude from .010" to .014" when doing the measurements for installation.
Some rear seals are OK as is but, not with a line bored/honed block.
rmcomprandy wrote:Measuring "crush" on a two piece, steel core, rubber type seal requires a totally different installation than when actually building the engine with the seal ends offset...
Thanks Randy!! That's how I measured it. Only took a few thousands from each half to get it within those specs. Then I offset the ends and installed the crank.
Good info. Thanks.
» How to cut rear main seal for proper crush
» Rear Main Seal
» Rear main seal ?
» Rear Main Seal
» rear main seal problem
» Rear Main Seal
» Rear main seal ?
» Rear Main Seal
