Front plate/water issues
+9
Wheelie58
fc2444
13 posters
Front plate/water issues Empty Front plate/water issues
Post  HorsinAround August 16th 2011, 12:00 pm
I have a front and mid plate and keep having trouble with the bolts working loose and water leaking between the plate and timing chain cover. I tighten the bolts and eventually it starts leaking again. Now I have to take the plate loose and change the gasket (not fun in the truck) because it won't stop leaking. Anyone have some tips for me to keep this from happening?
Also, is there an aftermarket timing chain cover for the 460 that isolates the water passages similar to a chevy? Perhaps this would end the problem.
http://www.frontpagefab.com
Front plate/water issues Empty Re: Front plate/water issues
Post  dfree383 August 16th 2011, 12:03 pm
Loctite on the bolts?
Post  69F100 August 16th 2011, 12:35 pm
dfree383 wrote:Loctite on the bolts?
X2 just make sure you some new bolts after the loctite drys you may brake old bolts getting them back out if they have already started rusting any.
Post  fc2444 August 16th 2011, 12:59 pm
We drilled ours out to .375 and used studs, problem solved.
fc2444
http://amr-coatins.com
Post  richter69 August 16th 2011, 1:20 pm
I don't use the gaskets, clean it good and a thin film of ta31, no gasket to get compressed overtime and loose the stretch on the bolts.
Post  IDT-572 August 16th 2011, 2:13 pm
I don't use gaskets either always leaked, I just use standard RTV, but the TA-31 is better.
Post  Wheelie58 August 16th 2011, 10:53 pm
The other tips are really good.
One more thing......if you do not have the motor plate tied in to the front of each cylinder head with solid spacers.....do so. It will take lots of load off of your 5/16" cover bolts.
Have fun...
Keith
Wheelie58
Wheelie58
Post  richter69 August 17th 2011, 8:26 am
^^^^^ mine is also this way, great minds think alike...... Cool
Post  HorsinAround August 17th 2011, 10:46 am
Thanks for the tips. What is TA31? not heard of that one. Keith, I wonder why my engine guy didn't mention that when I took it in for freshening the last time. I'll drill in some holes on the plate and make up the spacers.
Post  Lem Evans August 17th 2011, 10:50 am
Front plate/water issues TA31
I use a gasket....I glue...not silicone... the gasket to the front cover and TA31 the plate to the gasket.
Post  BOSS 429 August 17th 2011, 10:55 am
use urtra black, and loose the gasket, even with gaskets weve never had one leak,we just use rtv now.
Is everything flat? burr somewhere? high spot?
Post  jbozzelle August 17th 2011, 10:57 am
I use the "right Stuff" grey stuff in the can by Permatex. Dries good and doesn't turn to slime like the older Permatex RTV stuff does. I noticed my bolts were loose when I pulled the engine out of the dragster. I might try using some studs on all of it next time.
Post  Lem Evans August 17th 2011, 6:34 pm
Alan, what is the front plate made of and how thick is it?
Post  DILLIGASDAVE August 18th 2011, 12:38 am
HorsinAround wrote:......keep having trouble with the bolts working loose and water leaking.........
Are you using travel limiters along with the front/mid plates?
Front plate/water issues Empty RE
Post  HorsinAround August 18th 2011, 11:05 am
Lem Evans wrote:Alan, what is the front plate made of and how thick is it?
1/4" Aluminum
Front plate/water issues Empty Re travel limiters
Post  HorsinAround August 18th 2011, 11:09 am
Not sure what you call travel limiters, but I do have frame connectors that go from the frame to a plate where the oem motor mounts go. Has heims ends at both ends. This limits front to rear travel, but allows for frame flex under load.
Post  Lem Evans August 18th 2011, 11:39 am
1/4" Aluminum
If properly torqued grade 8 bolts are loosening the plate may be flexing and letting the bolts relax.
Front plate/water issues Empty Re Ta31
Post  HorsinAround August 18th 2011, 11:48 am
Lem Evans wrote:Front plate/water issues TA31
Thanks for the pic Lem. I'll pick some of that up.
I think I'm going to try loosening the plate up enough to squeeze some sealent in to get by until I take the motor out at the end of the season.
Post  HorsinAround August 18th 2011, 11:50 am
Lem Evans wrote:
1/4" Aluminum
Does anyone make a thicker front plate that is 39-40 inches wide?
Post  res0rli9 August 18th 2011, 12:09 pm
Keith will make what ever you need. He's a member here Smile
http://www.keithfulpmotorsports.com/
Post  Wheelie58 August 19th 2011, 12:39 am
Alan,
I can make just about anything that you need for motor plates and mid plates for BBFs. My normal laser cut plates are 6061 T6 1/4" aluminum. The only application that reportedly needs a thicker plate would be something like a monster truck that sees lots of G forces in many directions. Other members have mentioned lateral limiters and that is important.
If your plate was not connected to the heads, and you correct that and make sure all of your fasteners are top notch, you should be OK.
One point to consider....one of the passenger side timing cover/water pump bolts on a BBF block is not a blind hole, and is exposed to the water jacket. If you do not apply some sort of sealant to the threads of that bolt, you will experience a leak that looks like a timing cover gasket.....but is not. It is the bolt directly below the water pump passage at the front of the block. The leak comes out of the small channel on the gasket surface.
That is a common problem. Folks who use lots of RTV on their cover gasket automatically get some on the bolt, and it is not an issue. More than one experienced racer has pulled the front cover to replace a "leaking gasket" to have the leak reoccur...and then learn about the bolt deal. Embarassed
I hope all of this helps. Call any time. 678-458-2033
Keith
Wheelie58
Wheelie58
Front plate/water issues Empty RE leak
Post  HorsinAround August 19th 2011, 10:49 am
Thanks for the tips Keith. My motor hadn't leaked since I freshened it over a year ago. The leak seems to be coming from the bottom of the drivers side water pump hole, and the very bottom. Tightening the bolts again seems to have stopped it at the pump hole, but not the bottom.
I do have the lateral limiters going from the old motor mounts to the frame, I just didn't have the bolts/spacers from the plate to the heads.
Post  kjett August 19th 2011, 10:14 pm
jbozzelle wrote:I use the "right Stuff" grey stuff in the can by Permatex. Dries good and doesn't turn to slime like the older Permatex RTV stuff does. I noticed my bolts were loose when I pulled the engine out of the dragster. I might try using some studs on all of it next time.
This is what I use with my 1/4" aluminum motor plate. And I'm bouncing the truck all over the place in a mud hole. Been working this way for the last 2 years with no issues. Very Happy
kjett
kjett
Post  Wheelie58 August 19th 2011, 10:59 pm
HorsinAround wrote:Thanks for the tips Keith. My motor hadn't leaked since I freshened it over a year ago. The leak seems to be coming from the bottom of the drivers side water pump hole, and the very bottom. Tightening the bolts again seems to have stopped it at the pump hole, but not the bottom.
If you need the spacers, I can whip some up...or you can see my buddy Gary Agan (Gary Agan Race Cars) up there in Indiana. I think that that addition will make things better along with some of the other tips from our pals.
Thanks,
Keith
Wheelie58
Wheelie58
