what autolight plug for scj heads?
Tennessee Bullitt
BigDave65
stanggt
What plugs are needed to run with scj heads with flattop 460 running 94 and 110 fuel. Searched but couldnt find any info.
stanggt- Posts : 494
Re: what autolight plug for scj heads?
I'm thinking we used a 25 once, but not 100% on that. You could go to Autolite's website and find part # for stock replacement and go from there.
BigDave65- Posts : 567
do they use a tapered or gasket style plug and what is the reach? These are the kaase design scj aluminum heads.
Straight thread, 3/4" reach, gasketed spark plug. Try the AR # 3934 with the 110 racing gas.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Lem told me to use ar3923
stanggt wrote:What plugs are needed to run with scj heads with flattop 460 running 94 and 110 fuel. Searched but couldnt find any info.
Presumeing that you were talking about the FRPP aluminum SCJ heads and not the OEM iron heads...
With a flat top piston you can run an extended tip spark plug #AR3911; (same heat range as a AR3934 but has an extended tip).
Ar 3934 is what Lem told me for my setup 472'' & flat tops with aluminum scj's
nuclearcobra- BBF CONTRIBUTOR
For street/strip engines........use 3934/3933 for track only .Tennessee Bullitt wrote:Lem told me to use ar3923
what about running a 3932 for a 16:1 motor (without N20)? Or is the 3932 too cold of a plug?
psfracer wrote:what about running a 3932 for a 16:1 motor (without N20)? Or is the 3932 too cold of a plug?
At 16:1 the 3932 should work....I assume you have a butt kicking ign box........not hotter than the 3933 at that high ratio i.m.o.
Thanks for info, almost ready to fire it up.
» Spark plug help 9.5:1 532 d3 iron heads,
» SPARK PLUG RECOMMENDATION FOR SCJ-A ALUMINUM HEADS
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
