what oil pump and pick up for swap
what oil pump and pick up for swap Empty what oil pump and pick up for swap
Post  johndickjr August 19th 2011, 8:11 am
ordering the oil pump and pick up today, i have the 460 truck rear sump oil pan , not for sure what year of oil pump and tube to order
johndickjr
what oil pump and pick up for swap Empty Re: what oil pump and pick up for swap
Post  f250mike August 19th 2011, 8:36 am
I think the truck pan started being used in 1984 on f250 4x4's.
Make sure you get the main bolt with the stud also.
f250mike
f250mike
Post  johndickjr August 19th 2011, 8:43 am
f250mike wrote:I think the truck pan started being used in 1984 on f250 4x4's.
dam, i forgot about that
johndickjr
Post  jbozzelle August 19th 2011, 10:57 am
Pan and pickups come matched. The Melling pump would be good for you unless you want to go big and splurge for the Kaase pump. Not sure if the Kaase pump will fit in a stock 4x4 pan though.
Post  f250mike August 19th 2011, 11:22 am
I bet any pump other than the standard melling will require some pan mods to clear.
f250mike
f250mike
Post  Paul Kane August 19th 2011, 12:53 pm
johndickjr wrote:ordering the oil pump and pick up today, i have the 460 truck rear sump oil pan , not for sure what year of oil pump and tube to order
Make certain you have the truck pan and not the van pan; they are slightly different and use slightly different pickups which bolt to different main caps.
Don't know the application of your engine but we have oil pumps in standard and high volume that suit just about every engnie build out there, and are very value priced.
Paul
Post  jbozzelle August 19th 2011, 1:01 pm
Do some searching on here too about some mods for that pan to keep the oil from climbing the rear of it while racing.
Post  johndickjr August 19th 2011, 3:31 pm
the pump is offering two different pick up tubes..one is 11-5/8..the other is 13-1/4 long
johndickjr
Post  69F100 August 19th 2011, 4:06 pm
John I believe the 11 5/8 is for the van pan it has the sump off centered to the rear that is what mine was anyhow and I am running a van pan on mine maybe this will help you on yours.
Post  johndickjr August 19th 2011, 4:19 pm
just got off the phone with summit racing..ordered the ford racing pan kit ..comes with the stud..oil pan..gasket..pickup tube ..dipstick..160.00
johndickjr
