need help picking a intake
need some guidance on picking the best intake for my motor, motor is a 429ci, ported doves (followed directions on mad porter site)2.19--1.76 ss valves..cam is a.640--.640 lift--240 dur @.050-...110 lob center... 2500-6500 rpm. solid roller..flat top pistons..motor is for drag racing only...looking at a few different intake..the stealth...victor and i have a blue thunder
johndickjr- Posts : 896
Re: need help picking a intake
You have the BT use it !!!! They work fine.
i forgot to say, the BT intake i have is for cj ports, my heads are ported but not to cj ports, should i bell mouth the heads to match or just run a mismatch portdfree383 wrote:You have the BT use it !!!! They work fine.
Run it as is, it still works. The Factory CJ intakes on Dove heads was a factory Upgrade back in the day and increases performance reguardless of the miss match. But if you want to spend the time you can match the heads to the CJ port. Just make sure to seal the valve cover bolts @ the intake ports or you could have a slight vac leak.
dont flame me..but are CJ ports and SCJ ports the same thingdfree383 wrote:Run it as is, it still works. The Factory CJ intakes on Dove heads was a factory Upgrade back in the day and increases performance reguardless of the miss match. But if you want to spend the time you can match the heads to the CJ port. Just make sure to seal the valve cover bolts @ the intake ports or you could have a slight vac leak.
ok..cool beans...then yes my BT intake has the scj huge sized ports.well i just checked..it has been a while since i ported them , i did port them out to scj size, i can see the hole in the port from the vc hole..ok..i had made a template from the intake and transferred it to the heads..its all coming back to me now..thanksdfree383 wrote:Yep
» picking a intake manifold
» picking a balancer
» help with picking a block??
» picking a power valve
» 552ci BBF not picking up how it should on the hose
