? for the country folk
+9
56Tbird
BigDave65
Larry T
Tommyj466
13 posters
? for the country folk  Empty ? for the country folk
Post  bruno August 25th 2011, 9:33 pm
can i increase the water pressure on the well pump ?
and no i will not us a Les Morris well pump engine Razz Razz Razz we still love yah bro ..... if you are still lurking Laughing Laughing
http://WWW.CKRME.COM
? for the country folk  Empty Re: ? for the country folk
Post  richter69 August 25th 2011, 9:45 pm
just turn the barrel valve up and it will rock............ Cool
Post  Tommyj466 August 25th 2011, 10:08 pm
put your thumb over the end of the spicket Very Happy
TJ
Tommyj466
Tommyj466
Post  Larry T August 25th 2011, 10:26 pm
you can increase the psi in the water tank by adjusting the cut off switch.you should have a water psi gauge some were on the tank.take the cover off the cut off switch and adjust the nut down about 1/2 turn.then get someone to run the water until the switch comes on and watch the psi gauge.when the presure switch cuts off the presure should have increased on the tank = moore presure at the fauset.i have mine set at 20 psi it wont blast off the barnicals off a ship but it does what i need. Smile
Larry T
Larry T
Post  schmitty August 25th 2011, 10:39 pm
Yes you can. Be carefull and do it like Larry said. I have most of mine set around 40 psi, but I have proper water line capacity for it. If you have weak pipes, extra pressure will sometimes burst these pipes. Shocked What kind of pipe do you have, plastic, copper, galvanized steel? Cool
Post  cool40 August 25th 2011, 10:40 pm
be sure and kill the power to the switch before you mess with it.you may also need more air in the psi tank.
Post  BigDave65 August 25th 2011, 11:33 pm
schmitty wrote:Yes you can. Be carefull and do it like Larry said. I have most of mine set around 40 psi, but I have proper water line capacity for it. If you have weak pipes, extra pressure will sometimes burst these pipes. Shocked What kind of pipe do you have, plastic, copper, galvanized steel? Cool
Thats the truth. When they finally ran city water through here the extra pressure blowed out 'bout every pipe between the meter and the house. Finally just had to redo the entire length of pipe.
BigDave65
BigDave65
Post  56Tbird August 25th 2011, 11:34 pm
No City Water???? I thought you was a Baller!!! Hot Damn boy,welcome to the real world Razz Razz king
56Tbird
56Tbird
Post  Frank Merkl August 26th 2011, 7:03 am
You guy's are pussy's , Town water pressure in Brooks, Alberta is 75 psi , Them waters save shower heads work good when you drill out the 1/8" orifice to 1/2" . on the Farm as we have to haul water I still run 75psi as I hate wimpy showers . PS ,my 6" pipe wrench and cordless drill and a super soaker shower head comes with me any time I'm going to be saying in a motel .
Post  dfree383 August 26th 2011, 8:50 am
Frank Merkl wrote:You guy's are pussy's , Town water pressure in Brooks, Alberta is 75 psi , Them waters save shower heads work good when you drill out the 1/8" orifice to 1/2" . on the Farm as we have to haul water I still run 75psi as I hate wimpy showers . PS ,my 6" pipe wrench and cordless drill and a super soaker shower head comes with me any time I'm going to be saying in a motel .
Got to be able to blast the Cow Poo out from between the toes !!!! Razz Laughing
Post  Lem Evans August 26th 2011, 9:11 am
Be sure to put some Clorox in the water...it'll kill the bacteria left by the cow pee that got in there during heavy rain events.
Post  jasonf August 26th 2011, 9:28 am
We have around 80 psi here with spikes up to 120 psi. If your system can't handle 40 psi without leaking then your plumbing is a POS.
Post  plowboy34 August 27th 2011, 2:12 pm
I have my pressures set at 30 for low side and 70 for high side. You may want to make sure your tank is not water logged cause if it is it will burn up your pump
plowboy34
Post  bruno August 27th 2011, 2:28 pm
THXS GUYS , IM GOING TO CK IT OUT THIS WEEKEND
