460 Trans Dapt Solid motor mount Wanted Found them !
460 Trans Dapt Solid motor mount Wanted   Found them ! Empty 460 Trans Dapt Solid motor mount Wanted Found them !
Post  davvet2 August 25th 2011, 9:53 pm
Looking for some 460 trans dapt solid motor mounts and a C-6 trans mount.
I've read 2 different things on this, some say run solid motor mounts and a urethane trans mount, others say run everything solid -- so I'm not sure which way to go.
I'm also still looking for a Blue Thunder dual 4-bbl. intake for D0VE C heads.
Thanks,
Jim
davvet2
davvet2
460 Trans Dapt Solid motor mount Wanted   Found them ! Empty Re: 460 Trans Dapt Solid motor mount Wanted Found them !
Post  IcallhimGeorge August 25th 2011, 10:30 pm
truck or car mounts?
IcallhimGeorge
IcallhimGeorge
Post  davvet2 August 26th 2011, 12:34 am
This is what I need (for Ford Truck):
460 Trans Dapt Solid motor mount Wanted   Found them ! Transdapt460mount
davvet2
davvet2
Post  res0rli9 August 26th 2011, 12:57 am
Don't run a solid trans mount.
Post  davvet2 August 26th 2011, 1:38 pm
OK, thanks.
The parts companies say you should run a solid trans mount with solid motor mounts.
I have a BB in one of my vehicles that has solid motor mounts and a solid transmission mount.
The transmission case cracked, and I thought it was because the solid trans mount bolts were loose.
I built a mid plate that bolts to the front of the trans case and anchors to the frame, thinking that torque twist cracked the case (along with the loose bolts on the solid trans mount).
Jim
davvet2
davvet2
Post  IcallhimGeorge August 26th 2011, 10:29 pm
Ive got a brand new set in the box. Ive never even mocked them up in the truck.
$60+shipping.
IcallhimGeorge
IcallhimGeorge
Post  davvet2 August 27th 2011, 12:17 am
PM sent.
davvet2
davvet2
Post  davvet2 August 27th 2011, 7:56 am
IcallhimGeorge wrote:Ive got a brand new set in the box. Ive never even mocked them up in the truck.
$60+shipping.
Kris,
PayPal sent to pay for the mounts.
Thanks,
Jim
davvet2
davvet2
Post  IcallhimGeorge August 27th 2011, 8:10 am
Thanks Jim!
Email me your address and they will go out today.
STGCountryboy312@aol.com
Kris
IcallhimGeorge
IcallhimGeorge
Post  IcallhimGeorge September 1st 2011, 12:47 pm
Jim is one helluva buyer.
Thanks again!
IcallhimGeorge
IcallhimGeorge
Post  davvet2 September 1st 2011, 8:01 pm
Kris is a great seller!
Mounts arrived as advertised and were shipped quickly.
Jim
davvet2
davvet2
