Tans Dapt motor mounts
QtrWarrior
Bigred69
Tans Dapt motor mounts Empty Tans Dapt motor mounts
Post  Bigred69 January 1st 2014, 3:56 pm
Motor mounts
Has anyone used these to mount a 429 ? They don't look real stout to me , but it says to mount BBF in anything.
380804978368 eBay item number
I thought these would be easier to cut to fit my frame, but wanted to hear what you guys think. Or if anyone has used them.
Bigred69
Bigred69
Tans Dapt motor mounts Empty Re: Tans Dapt motor mounts
Post  BOSS 429 January 1st 2014, 4:48 pm
Bigred69 wrote: Motor mounts
why not just get the right ones?
Post  Bigred69 January 1st 2014, 5:03 pm
[quote="BOSS 429"]
why not just get the right ones?[/
So, you have not ever used these? Thanks. I guess I was wanting to know if anyone has ever used them on a project. And, I guess " the right ones" are either aftermarket or out of another model. And no part of my project is sponsored, or funded by anyone but me. I have two kids in college and don't really feel like spending $250-$450 on mounts that are 3 piece and most likely not give me the height I want on the motor.
Bigred69
Bigred69
Post  QtrWarrior January 1st 2014, 6:30 pm
I have to sort of agree with Rich on this one...
Most big Fords share the same crossmember "arrangement"..i.e. even if the car never came with a 460, the mount holes are probably there. The main thing is to identify a car that had a 460 with the similar frame... Also, believe it or not, most of these type of parts are still available at Advance or Autozone at reasonable prices.. They may not have it in stock, but they can order it..
It also makes it easier to hook up everything else when you use factory parts..i.e... driveshafts may not have to be made, shift linkages work, off the shelf headers fit... you get the idea...
QtrWarrior
QtrWarrior
Post  Bigred69 January 1st 2014, 6:49 pm
Well, than maybe I'm missing something here. The only mounts I have found are either aftermarket (crites), or from a 70 Torino . The crites mounts are $250, and the others even used are $300-$450 for a set. I have looked in my auto parts catalog and nothing can be found ,other than what I mentioned. I guess what I'm saying is , I have been looking for a while for motor mounts. Still no answer on the other mounts I mentioned. Nobody's used these I'm taking it.
Bigred69
Bigred69
Post  QtrWarrior January 1st 2014, 7:39 pm
I'd be willing to bet $$$ that mounts from a 72-74 Torino would work..
They have a full frame just like yours..
QtrWarrior
QtrWarrior
Post  BOSS 429 January 1st 2014, 7:39 pm
I use 2 diff kinds of mounts the right ones,or a motorplate that I have made , Now I just went to ebay for you theres a complete set of 6 piece's there 449.00 ,plus theres all kind of single pices for you on there,its either that or make something, I understand all about a low $$ builds
never have used the ones your talking about
Post  BOSS 429 January 1st 2014, 7:41 pm
QtrWarrior wrote:I'd be willing to bet $$$ that mounts from a 72-74 Torino would work..
no 72 and up is full frame,and a diff mount,70 or 71 torino/cyclone is what he needs 3 peice's per side, 68 69 70 71 torinos , fairlanes don't have full frames
Post  Bigred69 January 1st 2014, 8:13 pm
No, they are totally different frame designs.
Bigred69
Bigred69
Post  QtrWarrior January 1st 2014, 8:16 pm
My bad...I thought that big Ford in the avatar had a full frame...
In that case...Maybe a 71 Mustang ?
QtrWarrior
QtrWarrior
Post  bigblok2000ranger January 1st 2014, 9:46 pm
How soon do you want them? I am working with my chassis shop to make some universal kits kinda similar to those but they will have 1 1/4" .120 DOM tube that you weld to the frame rails or crossmember to suit individual needs, the kits will include a pair of urethane bushings, the plates that bolt to the block, and tabs that you weld to the block plate. I have the plans for SBC/BBC, 429-460, and working on plates for LS based engines. Should be able to have pricing by this weekend hopefully.
bigblok2000ranger
bigblok2000ranger
Post  jeffgfg January 2nd 2014, 4:53 pm
Check out Speedway they have 429-460 mounts that you can cut and fit into your chassis. Part # 720-4503 100.00 a pair. Never used them but they look stout. www.speedwaymotors.com
jeffgfg
Post  Bigred69 January 2nd 2014, 4:58 pm
2014-01-02
jeffgfg wrote:Check out Speedway they have 429-460 mounts that you can cut and fit into your chassis. Part # 720-4503 100.00 a pair. Never used them but they look stout. www.speedwaymotors.com
That's funny, because that is exactly what I bought last night. I was unsure of how stout they were. I called and they told me that each mount weighs over 7 lbs, and uses a 7/16" bolt. They should be very easy to cut and fit. My plan is to use them in conjunction with the steel chairs that bolt to the crossmember. I plan to weld them to the chair ,so if I want to pull the motor I can get that out of the way and the engine plate can stay bolted up. I am on a budget, and spending $450 for mounts that don't give me any room to adjust motor height just isn't something I want to do. Thanks for the info .
Bigred69
Bigred69
Tans Dapt motor mounts Empty Trans Dapt Mounts
Post  7LBRONCO January 20th 2014, 10:35 pm
I bought a set of solid steel mounts that Trans Dapt now sells. They mount my 429 in place of a 400. Been in 6 years now. 35" tires, 4.56 gears, and a heavy foot. They fit perfect on my Bronco, fan in center of shroud, etc.
7LBRONCO
Post  7LBRONCO January 20th 2014, 10:37 pm
7LBRONCO
Post  pistol25 January 20th 2014, 10:52 pm
the 71-73 mustang is basically he same under the hood as a torino. a set from those cars will work with very minimal work.
pistol25
Post  Bigred69 January 21st 2014, 6:59 am
Trans Dapt mounts went back to the place I bought them. Bought the Crites and motor is now bolted up. There was not enough room to make the trans Dapt work. Tight down there.
Bigred69
Bigred69
