MSD-7al-3 problems?
+9
56Tbird
psfracer
BigDave65
airford1
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
MSD-7al-3 problems?
Engine has a mid rpm range miss so I check the timing and it's at 22', but only advances to 32'. Tried to reset initial timing back to 14' and the engine doesnt want to idle. I have sent this MSD box back before for the timing going crazy. what else could it be? Here we go , coil, dist, dist gear, bad mechanical advance, plugs/ cap and rotor,,,,,,,,,,,,,,,,,,,,,,
airford1- Posts : 192
Re: MSD-7al-3 problems?
Do you have zero chips in the timing retards or have all the retard terminals grounded?
What distributor are you using?
BigDave65- Posts : 567
Yes zero chip in all timing retards and I am running a MSD pro billet magnetic trigger dist. Pretty simple. It is starting to act like the rev limiter is coming on.
Have you changed out the rev limiter chip? They've been known to go bad before.
jbozzelle- Posts : 3705
mine did this year and Blake had one also go bad about the same time. if your timing is moving around and you rule out the diz,check your endplay on your cam. fords dont often have the issue like a chevy with the roller and cam button B/S.jbozzelle wrote:Have you changed out the rev limiter chip? They've been known to go bad before.
I acts like the rev limiter is coming in . I had the same problem when it was new and sent it back to MSD, they replaced a resistor board and sent it back. I got about 30 passes on it and it's starting to do the same thing.I will swap the box out and if its the box I'm really pissed.
i've been told the 3box was a pos,but i never had one.
I had problems with my 7AL3, changed out to the 7AL2 Plus and haven't had a problem since. My timing was moving around also, and I had zero chips on all for retards as well.
My 7AL3 is back at MSD right now ,for the 3rd time in the last 18 months!! I'm not real pleased with it at ALL. $169 last trip to fix it. At least this time it just completely quit after 2 passes of of clicking on and off at full throttle. Hopefully it didn't lift a head gasket or something worse this time!! It may have to find a new home
56Tbird- BBF CONTRIBUTOR
I just talked to MSD and they're going to send me a different 7AL3 since mine has been back 3 times in the last 18 months. I hope it's better than the last one!!
I would have them send you an 7AL2 Plus instead, seriously, unless you need the features of the 7AL3.
I know some have had issues with the 7AL-3's. but I've had one since my car was new in 1998 and (knock on wood) I haven't had the first issue with it. I guess it's cause I bought a used box out of a P/S truck to keep for a spare. I've tried blaming the box for troubles a few times but it's never caused any.
A friend and I chased 7AL3 gremlins after switching from 6AL and 7AL2 boxes. After the boxes made repeated trips back to Texas for repairs, (MSD kept saying they were OK when they received them.) we started looking at other stuff. We found that we had to readjust rotor phase in order to make the car run right.
That is to say that when we swapped a 7AL3 into a good running car (removing either a 6AL or a 7AL3) the rotor phase had to be changed in order to get the car down the track. No, I can't explain it, either, but......
Anyway, since yours was running OK before, then developed the problem....I doubt that's your trouble, but I thought you guys might wanna know.
maverick- BBF CONTRIBUTOR
The 7AL-2 Plus is a very good ignition.........if a guy needs more it looks like jumping to 7 Digital is the way to go.
So far I would have to agree. I is a shame to have a back up box just to know you can go racing for the weekend.cool40 wrote:i've been told the 3box was a pos,but i never had one.
i still run the 7al2 i bought new back in the mid 90's and it works every time.
X2,and I have another for a backup,so mine should last forevercool40 wrote:i still run the 7al2 i bought new back in the mid 90's and it works every time.
Let me be the first to say,,, MY BAD, the MSD 7al3 wasn't the problem. I had .035 end l play in my dist., and 3 plug wires with triple the OHM's reading. I will still keep my eye on the box because it a character you cannot leave home alone. We be drag racin again.
u figure out issue
I've been struggling to get my 608 bbf alcohol motor to go past 5500 rpm...check alcohol system ...timing at 32-36....
Don't pop or bang...starts good...idles good...just no top end...I've checked bout everything ..
Msd replaced a start retard board n Saussure its good to go...
also tried different chips.
This is my first alcohol motor n am struggling.
Thanks for ur help
Jason
Thanks for ur help
Jason
bbfdragster- Posts : 121
bbf drag I would start a new thread. My problem was not the MSD 7 box and it turned out to be the crank shaft was .0008 smaller than the timing gear which made my timing move around. I use the timing retard to start and goto 30' after it starts. When I get to 3000rpm the timing moves back to 29' and I am living with that.
bbfdragster wrote:I've been struggling to get my 608 bbf alcohol motor to go past 5500 rpm...check alcohol system ...timing at 32-36....
Thanks for ur help
Jason
sounds fat fat fat........ what pump, nozzel etc? seems we've discussed it before.
Injection info
Possible...been on this problem for couple years...n this year I had to redo wife's kitchen.
80-a1...7.5 gal....40 nozzle ....30% leak down on barrel valve...
n yes plugs r wet When I get back...
Boutght high speed bypass but haven't installed yet...
almost ready to go back to carbs.
Thanks for ur help guys.
Jason
Jason
nozzles are big,IMO.what main pill? whats the oil look like? if its fat it'll milk the oil.go here... http://fuelinjectionenterprises.com/ and do the user name etc etc,it's a free site,and check out the tuneup calculator.i've used it and its very close as long as the info you put in is right.my 526 likes less timing,28-30*,just a thought.bbfdragster wrote:Possible...been on this problem for couple years...n this year I had to redo wife's kitchen.
Jason
I have a 7al-2 msd box on my car and it has been a great box no problems.
460 lincoln- Posts : 2
Update. Friends and I now have five MSD 7AL3 boxes working flawlessly. It's not a POS, but does require a couple of different setup details. You can't just plug one in place of a different box and run. We love ours.
Page 1 of 2 • 1, 2
» oil psi problems
» problems with 460
» VAVLE HEIGHT SETUP RANGE FOPR OEM dove 429 HEADS
» C6 problems
» C6. Slow shifting
» problems with 460
» C6 problems
» C6. Slow shifting
Page 1 of 2
