whats this worth?
stanggt
whats this worth? Empty whats this worth?
Post  stanggt August 30th 2011, 9:59 am
572 BBF
Crower billit steel crank 4.5
Childs & Alberts aluminum rods
BRC flat top pistons
new rings
new bearings
erson 740/760 solid roller cam and lifters
Harland Sharp 1.7 rockers
matching valvesprings,locks and retainers
Crower 3/8 pushrods
victor 460 intake
aluminum balancer
Moroso valve covers
moroso 9 qt oil pan
High volume oil pump
71 460 4 bolt block filled half way
what is this stuff worth? no heads
stanggt
stanggt
whats this worth? Empty Re: whats this worth?
Post  rmcomprandy August 30th 2011, 10:03 am
New? All old parts with not much time left? Threads worn out or hardly used? Etc.
Post  stanggt August 30th 2011, 10:08 am
rmcomprandy wrote:New? All old parts with not much time left? Threads worn out or hardly used? Etc.
oh ya that would be some good info, used, all ckd out, has five passes on all in a competition pulling truck.
stanggt
stanggt
Post  schmitty August 30th 2011, 12:42 pm
The block by itself is about a grand, and then add up the rest of the parts for what they are worth. Cool
Post  stanggt August 30th 2011, 3:08 pm
reason im asking is I can trade my new unassembled 418 stroker windsor short block for it. I have 3k into the small block.
stanggt
stanggt
Post  DanH August 30th 2011, 3:51 pm
stanggt wrote:reason im asking is I can trade my new unassembled 418 stroker windsor short block for it. I have 3k into the small block.
572 BBF from a 71 block . even if together have the cyl. walls sonic . check . you muxt have missed the questions posted above . new/ used / worn out and time to dump on some fool ( I put a liTTLE EXTRA IN THE QUESTIONS)
DanH
Post  schmitty August 30th 2011, 4:52 pm
Just for a reference, the crank would cost over $3k new. Not sure if that helps or not. Wink
Post  stanggt August 30th 2011, 5:32 pm
I responded in the 3rd post that they were used with only 5 passes on the parts in a pulling truck. the block is obviously older. Its all apart right now,all parts were ckd out at local speed shop and are waiting to be picked up. Ckd for cracks,stretch,straightness,etc.
stanggt
stanggt
Post  cool40 August 30th 2011, 9:41 pm
you need to trade! Very Happy
Post  longroofracer August 31st 2011, 3:17 am
Why is it all apart after 5 passes?
longroofracer
longroofracer
Post  stanggt August 31st 2011, 9:20 am
went with an aftermarket,bigger motor, wanted more. Thats what I was told
stanggt
stanggt
Post  Paul Kane August 31st 2011, 11:29 am
stanggt wrote:572 BBF
new rings
new bearings
Crower 3/8 pushrods
victor 460 intake
aluminum balancer
Moroso valve covers
moroso 9 qt oil pan
It's well worth the trade, value-wise.
