weekend project ????
+6
bosshoss
10 posters
weekend project ???? Empty weekend project ????
Post  bruno September 2nd 2011, 10:58 am
yes im going to put these wheelie bars on ....... so i bought these wheelie bar brackets cnc out of m/s ...what do i need to watch out for when im welding these to my 8.8 ? do i need to remove the fuel cell ? Shocked how thick is the axle tubs ? do i need to let these welds cool down ....etc .....
http://WWW.CKRME.COM
weekend project ???? Empty Re: weekend project ????
Post  Doug Rahn September 2nd 2011, 11:25 am
Nick, I would definitely remove the fuel cell and plug the line! I just guessing on the tube thickness for the 8.8, but it is probably around 3/16". Be careful about to much heat in one area or you could warp the axle really bad. Make short welds that have good penetration, then move over to the other side of the axle while that one cools down. Just keep alternating from side to side with short beads.
Post  bosshoss September 2nd 2011, 1:45 pm
Might be easier to tack them in the car and then drop the housing out and do the finish weld away from the car.
X2 or 3 on warping the tubes.
dkp
bosshoss
bosshoss
Post  whatbumper September 2nd 2011, 7:01 pm
Short welds, take your time. tubes are thin but managable. good luck
Post  69F100 September 6th 2011, 7:26 pm
Nick did you get them welded on or did you get scared lol!
Post  bruno September 12th 2011, 7:17 pm
69F100 wrote:Nick did you get them welded on or did you get scared lol!
YES I DID .... had an appointment at the " local chassis" guy and he stood me up ...so im now mocking up the brackets my question is
how much room do i need between the top bars and the bottom of the bumper ?
Post  Curt September 12th 2011, 7:44 pm
bruno wrote: my question is
.001 Razz
Post  richter69 September 12th 2011, 9:45 pm
If they are unsprung it dont need a whole lot, a ladder bar deal under power they are gonna gain clearance anyway lol.
How much room do you have now? How much between the ground and the wheels?
Post  bruno September 13th 2011, 7:31 am
richter69 wrote:If they are unsprung it dont need a whole lot, a ladder bar deal under power they are gonna gain clearance anyway lol.
i didnt measure it but if i had to guess the wheels are 6" off the ground and 6" off the top bar to the bottom of the bumper ......ive got to notch out the brackets to fit on the back side of the ladder bar deal , the width of the wheelie bars dont allow the brackets to sit on the axles ......
Post  richter69 September 13th 2011, 8:37 am
I'd move um up 3-4" and leave some room for adjustment with the heim ends either way.
Post  bruno September 13th 2011, 12:02 pm
richter69 wrote:I'd move um up 3-4" and leave some room for adjustment with the heim ends either way.
SO THERE WILL BE ABOUT 2-3" FROM THE BUMPER ........ so another thing about these bars which might hurt me is that they are double walled , which i heard i designed for higher horsepower cars/weight
Post  richter69 September 13th 2011, 1:03 pm
just use them to keep it off the bumper, it'll be good................
Post  jbozzelle September 13th 2011, 3:07 pm
What kit are you using? How long are they?
Post  bruno September 13th 2011, 4:01 pm
jbozzelle wrote:What kit are you using? How long are they?
Built by Chris Mann ...i believe thats his last name ...they are 80" doulbe walled
weekend project ???? DSC01000
weekend project ???? DSC00999
weekend project ???? DSC00998
Post  bruno September 13th 2011, 4:03 pm
that last one was blury
weekend project ???? DSC00997
Post  res0rli9 September 14th 2011, 12:50 am
Nice
Post  curleysracecars September 17th 2011, 12:02 am
Not sure what "double walled" means. They look to be 1.125" tubing. The top tubes will not move "upwards" much so they can be close to the bumper. I would mock them up at ride height will weight in the car, about 6" from the ground to the center of the wheel. Put your heim joints about 6-8 full turns out from being all the way in, and go from there. Good luck!
curleysracecars
curleysracecars
http://www.curleysracecars.com
Post  bruno September 18th 2011, 6:20 pm
curleysracecars wrote:Not sure what "double walled" means. They look to be 1.125" tubing. The top tubes will not move "upwards" much so they can be close to the bumper. I would mock them up at ride height will weight in the car, about 6" from the ground to the center of the wheel. Put your heim joints about 6-8 full turns out from being all the way in, and go from there. Good luck!
thank you for the input
here are the brackets mocked up on the 8.8
weekend project ???? 304813_2435554776208_1471880983_32775043_1040466901_n
Post  bruno September 18th 2011, 6:25 pm
and here they are done ..... had to get up early this morning to have some quality time with the welder , hopefully the bars stay on Smile
weekend project ???? 320949_2435560296346_1471880983_32775049_1970520851_n
Post  whatbumper September 18th 2011, 10:05 pm
looks good. I didn't realize you still had an 8.8. 8.8's and ladder bars are usually a no-no so keep and eye on those axle tubes.
Post  jbozzelle September 18th 2011, 11:25 pm
Nick
Is it just an optical illusion from the camera or is that track locator bent? Looks like it has a bow in it in both pics...
Post  bruno September 19th 2011, 7:59 am
jbozzelle wrote:Nick
hum will put a straight edge on it right now !!! will report back ......
