A460 block
Fordman
A460 block
Hello to all, and Thanks for any answers/suggestions in advance.
I am having a 545 built, and i was wondering if the stock main bolts are good enough for around 850hp, or should I go ahead and replace w/ARP main studs?
A460 block
TFS A460 heads
A460 block
TFS A460 heads
Fordman- Posts : 6
Re: A460 block
the stock bolts are more than fine.........
Re: A460 block
i put studs in mine and use the stock outter bolts on the center 3
caps seems to work fine but eather way should work
jesse- Posts : 447
Re: A460 block
stock bolt will handle anything you throw at it.... Studs are just a convenience.....
the Coug- Posts : 3055
Re: A460 block
I am of the opinion that the straight-shanked ARP main studs for the 460 are a step backwards from the OEM bolts that come with the A460 blocks....and in most cases even the passenger car blocks (that's what experience tells me).Fordman wrote:
A460 block
TFS A460 heads
But will those ARP studs be adequate for your targeted 850 hp when using the A460 block? Probably. but I'd say the factory supplIed fastener hardware is better suited for a LOT more.
Paul
Re: A460 block
The bolts that come with the FRPP A460 have been used in many 1,000+ HP engines and NOS to boot. If a guy feels like he needs something that has ARP on it , use the ARP main bolts........they are of a better design than the studs i.m.o. And the block would not have to be re-linehoned.
Re: A460 block
Perspective #2: we just subjected an A460 block with factory main bolts to more than 90% nitromethane, making thousands of horsepower, for three solid miles per pass...and did so several times. 850 hp ain't no thang.
Paul
Paul
Re: A460 block
Thanks for all of the reply's!
I am going to leave well enough alone and tell my engine builder to start putting this bad boy together!
Fordman- Posts : 6
Re: A460 block
Fordman wrote:Thanks for all of the reply's!
the Plus with this is you saved about $500 to boot for the Studs and machine work....
Re: A460 block
i should have asked the same question a few yrs ago when i did my svo block
lol
lol
jesse- Posts : 447
Re: A460 block
jesse wrote:i should have asked the same question a few yrs ago when i did my svo block
lol
What you need Jesse is a real machine shop not that fly by night you used
Re: A460 block
very true
that is why i went to line's performance
it didi cost a bit more but he has way better stuff
and ton of knowalge so far motor has been running better than ever
but he did have his hands full fixing the other shops work
jesse- Posts : 447
» Cometic MLS head gaskets
» Differences between stock type block and the a460 block?
» distributer block hole is too small on an A460 block
» wanted a460 block or eliminator block.
» wtb A460 block or Eliminator Block
