Dang Im bummed tonite........
Moodyblues
Dang Im bummed tonite........ Empty Dang Im bummed tonite........
Post  Moodyblues September 6th 2011, 8:49 pm
My D0VE headed 514 has started laying down on me. Eight (Cool, yes eight years of many passes shifting anywhere from 6100-5800 running around 5.80-90s. I'm bummed cause this has been a hell of a motor.
Gotta decided where to go from here. The D0VE heads just hold too much heat on gas and i'm not sure about an alky carb setup.
I can go with alky and refresh ol Moody or I can go with some aluminum heads and hope to run some 5.50s and not turn it over 7000.
Car ran best of 5.79 with this motor on gas. 2350 tube chassis 77 Mustang II, 1.76 glide, 4.88 gear.
Any thoughts on running alky with current combo in regards to et?
Will aluminum heads cool it down? Griffin radiator and meziere pump.
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
Dang Im bummed tonite........ Empty Re: Dang Im bummed tonite........
Post  cool40 September 6th 2011, 9:04 pm
alky will sure cool it down but i'd inject it,the rons stuff works good.some pick up a little with alky and some dont.your tune up sounds very good on gas so you may not see much with alky.i've ran it for a while now and i like the cooling part about it.get it tuned in and warm it up good so the oil dont turn white! Smile
Post  Lem Evans September 6th 2011, 9:21 pm
Do you need a set aluminum heads...yes. You do not need to get them for cooling [they will run cooler] . You need to get them because they will give more performance.
I've seen the story before........get a guy to spend same money changing to methanol that it would cost to get rockin' aluminum heads.
After one gets the aluminum heads he could use any fuel he/she wishes.
Post  Moodyblues September 6th 2011, 9:24 pm
Lem say I get a good set of ported heads from you. Will the D1VE 2 bolt block be ok shifting 6500-6800for a 5.50 et?
Moodyblues
Moodyblues
Post  Lem Evans September 6th 2011, 9:30 pm
[quote="Moodyblues"]Lem say I get a good set of ported heads from you. Will the D1VE 2 bolt block be ok shifting 6500-6800for a 5.50 et?[/quote
Damed if I know.....I do not port heads but I know ones that do.
It'd sure speed up........cam, carb, etc would matter.
Post  richter69 September 6th 2011, 9:37 pm
please dont put it on alky, I dont wanna hear all the "why didnt I do this sooner" stuff............... Laughing
Post  Lem Evans September 6th 2011, 9:45 pm
richter69 wrote:please dont put it on alky, I dont wanna hear all the "why didnt I do this sooner" stuff............... Laughing
Or, a guy could wake up and say ..."I got methanol and my cyl. heads still sux" .
Post  cool40 September 6th 2011, 10:42 pm
Or,a guy could buy a set of cyl heads AND put alky on and go realy fast AND be cool doen it! Wink studs and girdles for sure............
Post  Lem Evans September 6th 2011, 11:04 pm
You must be reading my mind Smile
I thought I said this at 9:21 PM today...........
"After one gets the aluminum heads he could use any fuel he/she wishes."
Post  cool40 September 6th 2011, 11:13 pm
Lem Evans wrote:You must be reading my mind Smile
you did.......i just made it where the rest of us fum ducks could read it. study
Post  the Coug September 6th 2011, 11:16 pm
Moody just buy you a set of aluminum heads and get them ported later if you need.... the plus is you also loose 80 lbs off your combo.....
Post  BOSS 429 September 6th 2011, 11:36 pm
why do you worry about keeping it under 7000 rpm?????????????????????????????????
old wifes tale, shifting it over 6800 wont hurt it, as long as the tune is right
Post  the Coug September 7th 2011, 12:05 am
BOSS 429 wrote:why do you worry about keeping it under 7000 rpm?????????????????????????????????
Rich that like a bunch of these guys will not bore one of these engines over .030 .060 at most.....
Post  richter69 September 7th 2011, 12:34 am
alky helped my old Dove headed deal run 2-3 tenths quicker.....both of um lol.
a guy can do what he wants...............I sure do lol.
Post  the Coug September 7th 2011, 12:37 am
Jon I personally think the alky would help on a iron headed engine for it would hold he heat better and burn cleaner. but thats JMO
Post  richter69 September 7th 2011, 12:45 am
I may need to put mine on gas this winter to kill some of the ass it has...........naw phuck that, I'll just change my ignition program this winter....................maybe an intake manifold............ Wink
