Need to swap a pinion yoke on a 9"
Need to swap a pinion yoke on a 9" Empty Need to swap a pinion yoke on a 9"
Post  jbozzelle September 11th 2011, 11:43 pm
Need to swap out a dragster coupler for a typical 1350 yoke? One I swap them does the gearset need any checking? Or do I just torque the nut down since the pinion is already shimmed and ring gear already set?
Need to swap a pinion yoke on a 9" Empty Re: Need to swap a pinion yoke on a 9"
Post  bosshoss September 12th 2011, 1:43 pm
As long as the pinion support has a solid spacer and not a crush sleeve you will be fine. Just retorque and good to go.
dkp
bosshoss
bosshoss
Post  jbozzelle September 12th 2011, 1:49 pm
OK. Thanks.
