Green Oil?
+13
342g
David Willingham
jc10000rpm
Dave Maxwell
KY JELLY
T. Neal
17 posters
Green Oil? Empty Green Oil?
Post  T. Neal September 20th 2011, 8:34 pm
Ok call me a dumb newbie but what the hell is this green oil you guys speak of? Question
T. Neal
Green Oil? Empty Re: Green Oil?
Post  richter69 September 20th 2011, 8:43 pm
More or less a joke between Lem and myself.....................its complicated lol.
The Schaeffer's oil myself and some others use is green in color. Its damn good stuff. Razz
Post  KY JELLY September 20th 2011, 8:57 pm
the schaeffer 's green oil is the best oil , the only thing better to have is a set of LEM evan's personal 11/5 roller lifters Razz
http://www.schaefferoil.com/
KY JELLY
KY JELLY
Post  Lem Evans September 20th 2011, 9:10 pm
It's the oil that they put the green stuff off of teeth in and stir it up. Wink
Post  richter69 September 20th 2011, 9:21 pm
then dip your shirt in it............ Wink
Post  Lem Evans September 20th 2011, 9:29 pm
wrong shade of green Wink
Post  richter69 September 20th 2011, 9:31 pm
yeah that was more like a key lime pie green.......................
Post  cool40 September 20th 2011, 9:53 pm
O..........so the green oil is kinda like "dont ask dont tell"? Razz
Post  Dave Maxwell September 20th 2011, 10:05 pm
Always wondered that myself, but was afraid to ask
Dave Maxwell
Post  jc10000rpm September 20th 2011, 10:26 pm
there are still some great oils made from Pennsylvania GREEN Crude Oil base. not sure if that is where Shaffers stuff comes from or not, but certainly "The old Kendall Oil" the new "Brad Penn Oil" and "Joe Gibbs Racing Oil" and others im sure.........................
jc10000rpm
Post  bbf-falcon September 20th 2011, 10:51 pm
jc10000rpm wrote:there are still some great oils made from Pennsylvania GREEN Crude Oil base. not sure if that is where Shaffers stuff comes from or not, but certainly "The old Kendall Oil" the new "Brad Penn Oil" and "Joe Gibbs Racing Oil" and others im sure.........................
Truth be known,it's probably all the same stuff.
Post  BOSS 429 September 21st 2011, 12:26 am
ill stick to kendal
Post  David Cole September 21st 2011, 1:36 am
My green oil is the Brad Penn semi-synthetic. It's supposed to be the same formula as the "old Kendal". I would try some Schaeffer oil, but their closest distributor is over 90 miles away.
I ran the "purple stuff" for the last 8 years, but their price increases finally put it out of reasonable reach for me.
Post  David Willingham September 21st 2011, 11:12 am
David, There is a distributor that lives two miles from me. Let me know if you want to get together and buy some.
David Willingham
David Willingham
Post  342g September 21st 2011, 11:58 am
I like the Brad Penn, used it for five years, and don't see any use to change, and the price is great. Very Happy
342g
342g
Post  IDT-572 September 21st 2011, 5:14 pm
My fleet trucks here are on Schaeffer, and the wear particles in my oil samples are in the 3-7 ppm range. Unbelievable.............
Also see a big drop in temps with it. I have used and tested it all but the Joe Gibbs and Royal purple is the only one that keeps wear down and temps like Shaeffer. But Schaeffer is under 5 bucks a quart verses 8 bucks for royal p.
Post  Lem Evans September 21st 2011, 7:42 pm
The question that begs to be ask....do the results have anything to with what color dye was put in the batch?
Post  KY JELLY September 22nd 2011, 8:48 am
Lem Evans wrote:The question that begs to be ask....do the results have anything to with what color dye was put in the batch?
I am sure you are correct on the color "maybe" being a dye , but there is NO other oil out there without aftermarket additives being added to it other than schaefer that will pass the bearing test the reps will perform for you to see from what I understand. I personally know 2 reps but have never seen or asked for the test to be performed.
I do know someone that owns a car that broke the oil pump drive shaft during the burnout , the burnout was finished and the driver did not notice the 0 oil pressure light was on and almost got the car staged before the owner got his attention to shut the car down. The end result was no bearing damage after complete tear down of the engine.
KY JELLY
KY JELLY
Post  Lem Evans September 22nd 2011, 9:50 am
Another advantage of green oil........you save money by not having to buy an oil pump. affraid
Post  John Myrick September 22nd 2011, 11:59 am
Lem Evans wrote:Another advantage of green oil........you save money by not having to buy an oil pump. affraid
Can I return mine ? Cool
-John
Post  Lem Evans September 22nd 2011, 12:04 pm
-John
10% restocking fee tongue
Post  Moodyblues September 22nd 2011, 5:53 pm
Kendall always known as "green oil" We used in in the 638 pro mod cheby back in the 90s
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
Post  LivermoreDave September 22nd 2011, 10:25 pm
Lem Evans wrote:It's the oil that they put the green stuff off of teeth in and stir it up. Wink
You may need "Green Oil" if your automobile has "five-bolt mains"... Wink ...
LivermoreDave
Post  dfree383 September 23rd 2011, 6:20 am
Schaeffer is some good stuff, I also like the Amsoil and Royal Purple products.
Post  Moodyblues September 23rd 2011, 9:57 am
Where do you get Schaeffer? How many on here use it?
Moodyblues
Moodyblues
