460 should have 500 hp but 1/8th mile calc says I have 300?
+10
zbob
DanH
Mark Laczo
truck-collector
14 posters
460 should have 500 hp but 1/8th mile calc says I have 300? Empty 460 should have 500 hp but 1/8th mile calc says I have 300?
Post  truck-collector September 20th 2011, 11:07 pm
I have a 10.5:1 cr 466 with edelbrock performer rpm heads, cam, intake with a holley 800cfm carb. Its in a 67 Ford truck with an automatic, 3.54 gears and 27 inch tall tires. I just took it to a local 1/8th miles strip. I had some tranny troubles (shifting from 2-3) but the best time I ran was 9.5 seconds. I estimate the truck to weigh about 4000 lbs. This build should be closer to 500 hp, but based off the time Im finding that I have 300??? Like I said I did have some tranny troubles which probably affected the time a bit, but still Im baffled. Any ideas??
truck-collector
460 should have 500 hp but 1/8th mile calc says I have 300? Empty Re: 460 should have 500 hp but 1/8th mile calc says I have 300?
Post  rmcomprandy September 20th 2011, 11:29 pm
Why do you presume this should be close to 500 horsepower...?
I certainly don't see that at all with all "Performer RPM" components ... MAYBE just over 400 or so. You must be believing the advertisements.
460 should have 500 hp but 1/8th mile calc says I have 300? Empty times
Post  Mark Laczo September 21st 2011, 1:51 am
Maybe your truck is 4500lbs or more if you are just estimating it also.
Mark Laczo
Mark Laczo
460 should have 500 hp but 1/8th mile calc says I have 300? Empty hp
Post  truck-collector September 21st 2011, 7:28 am
Im basing it off of similar builds that Ive read about in magazines using the same parts that acheived 500 hp on the dyno.
truck-collector
Post  DanH September 21st 2011, 8:36 am
truck-collector wrote:Im basing it off of similar builds that Ive read about in magazines using the same parts that acheived 500 hp on the dyno.
I got the same parts as a guy that can run a 4 minute mile .
DanH
Post  IDT-572 September 21st 2011, 9:40 am
Ruff crowd,
Truck Collector All the parts can be there and the tune be off or one part miss matched and your hp goal may be far from what you are looking for.
Most new combinations go to the track for the first time and are disappointing. But after several trips to the track , tuning ,leave technique, gear ratio change, things finally come around.
But the engine combo you have I doubt like Randy M said will make that kind of power.
I don't see your converter listed, and if it's too tight not leaving at toque peak or at least close it will be a pig on 60 ft and that will kill your E.T.
Give us some more info.
Post  richter69 September 21st 2011, 10:08 am
track elevation? air density? brake caliper dragging?................... Very Happy
460 should have 500 hp but 1/8th mile calc says I have 300? Empty Thanks for the feedback
Post  truck-collector September 21st 2011, 1:06 pm
After reading my post I realize its a little vague and left out a lot of variables. It was late when I posted it. Either way, theres enough builds out there that show these parts can reach that horsepower level. I had this engine built for me when I was in my early 20s -about 8 years ago-by an engine builder. Since I built the truck for the street Im not going to worry about it. This was the first and only time its ever been to the strip.
truck-collector
Post  cletus66 September 21st 2011, 6:42 pm
I knocked over a second off of my E.T. when I discovered that my carb was not opening all the way. Embarassed It is called workin' the bugs out......
Post  zbob September 21st 2011, 8:25 pm
i have a edlebrock headed 466 too. it ran a 12.5 actual in byron, 1/8 was 8 flat....using drag times correction bullcrap it came out to 12.3,,,gears are 327 with 26 tall tires. weight was 3250 with me in it. carb is a 750 vac sec. hopes that helps you gain some perception. bobn
zbob
Post  69F100 September 21st 2011, 9:00 pm
One more thing to think about is if you have a 500hp engine and the drive train is not set up for it,it is not going to show the 300hp is more than likely rear wheel hp and not bad for a street ride.
Post  dfree383 September 22nd 2011, 2:10 am
need to post more about your build and have the truck scaled.
The RPM cam is a rather poor choice now days.
What Convertor and what have you done to tune the engine?
460 should have 500 hp but 1/8th mile calc says I have 300? Empty What you need
Post  manofmerc September 22nd 2011, 6:56 am
You need at least 4.11 gears get your trans problem corrected and what type of convertor do you have .Check your ignition timing and is your carb opening all the way .Do you have slicks by the way?My 3400 pound comet runs 7.26 in the 1/8 466 edel heads 11.67 compression 4000 stall 4.56 gears solid flat tappet cam.Sometimes you have to work hard to speed up your vehicle Doug
manofmerc
Post  jc10000rpm September 22nd 2011, 7:02 am
what is average cranking compression ?? 3 things make them run, spark, fuel, compression get theese three right and u should be able to make what ever the combo is capable of
jc10000rpm
Post  truck-collector September 22nd 2011, 3:52 pm
Thanks everyone for your input-youve given me a few things to think about-action items- check carb, check compression, get tranny fixed. The convertor is a hughs rated at 2400 however I think I need more because even w this convertor the truck is ready to move as soon as its in gear. And that just doesn't seem right. I actually feel sort of silly having posted this and I was a bit nieve to think I'd get top performance right out of the box. Maybe ill even take the truck to the scales to see how much it really weighs. Title weight is 3910 but that was w the old fe and cast iron 4spd and dual tanks all of which are gone n
ow.
truck-collector
Post  IDT-572 September 22nd 2011, 4:00 pm
truck-collector wrote:Thanks everyone for your input-youve given me a few things to think about-action items- check carb, check compression, get tranny fixed. The convertor is a hughs rated at 2400 however I think I need more because even w this convertor the truck is ready to move as soon as its in gear. And that just doesn't seem right. I actually feel sort of silly having posted this and I was a bit nieve to think I'd get top performance right out of the box. Maybe ill even take the truck to the scales to see how much it really weighs. Title weight is 3910 but that was w the old fe and cast iron 4spd and dual tanks all of which are gone n
ow.
We would really like to hear what you find............... Keep us posted. Wink
Post  airford1 October 2nd 2011, 8:58 pm
ow. You got to start with a pass down the track and try to improve from there. There is nothing better than shaving off a tenth each time you go to the track. It keeps me awake at night.
airford1
airford1
Post  bigblok2000ranger October 3rd 2011, 10:15 am
Once all the mechanical stuff is correct it is usually a matter of learning what the combo likes; launch rpm's shift rpm's.... On more than one vehicle I have built I have dropped a complete second or more off my ET's just by figuring out what the combo wanted.
bigblok2000ranger
bigblok2000ranger
